Old 07-10-2017, 12:08 AM   #1
Iv painted my roof bars
Hi Guys
After washing, clay barring and polishing my S a the weekend I decided to put right something that has been annoying me for a while....
The roof side bars seem to have lost a bit of their colour and picked up a few little scratches in their 17 year life.
I carefully masked them off then gave them a very light sand down, wiped them with some panel wipe and a tack cloth then sprayed 3 coats of satin black.
From start to finish it took about 40 mins.
Im very happy with the results as they look like new now.
YellowS2000 is offline   Reply With Quote
Old 07-10-2017, 12:10 AM   #2
After
Here is a picture of the finished result
Old 07-10-2017, 12:15 AM   #3
Ash tray delete
Oh ye I also fitted an ashtray delete kit
Old 07-10-2017, 04:17 AM   #4
Roof bars look great nice work . Ash tray delete is on my list of things to do .
rfuerst911sc is offline   Reply With Quote
Old 07-10-2017, 05:01 AM   #5
Like my ashtray
I actually like having the ashtray door in place, I just use the area to store loose change.
Old 07-10-2017, 05:08 AM   #6
mavis.d's Avatar
What a good idea, might have to put that on my to do list!
mavis.d is offline   Reply With Quote
Old 07-10-2017, 05:36 AM   #7
Artist, 986S tinkerer
NewArt's Avatar
I've found that the "Back to Black" product works fairly well on plastic parts.
Old 07-10-2017, 05:56 AM   #8
Filastein's Avatar
Solution Finish FTW
2 0 0 1 S
Filastein is offline   Reply With Quote
Old 07-10-2017, 08:20 AM   #9
Chuck W.'s Avatar
Very nice job. It's the small things that really catch your eye after completing them.
1995 Porsche C4 Cab
Old 07-10-2017, 08:28 AM   #10
Chuck W.'s Avatar
1995 Porsche C4 Cab
Old 07-10-2017, 08:54 AM   #11
Thanks, I really would recommend the ashtray delete just for the fact the plastic isn't covered in that weird coating that the consul is.
That was one of the reasons the ashtray had to go.... it was covered in scratches
Old 07-10-2017, 09:05 AM   #12
thanks
Thanks guys for your kind words I'm glad my simple improvement was liked.
Car wasnt too shabby before hand but now it just looks that little bit fresher.
Next improvement has to be the silver release catches on the drivers sill, they are quite badly scuffed.
going to smooth them then base coat / clear coat them in 2 pack. my friend has a vinyl company so he will reproduce the little car symbols that go on them.
WORD OF WARNING FOR YELLOW CARS..... don't know if you can see in this picture but due to a little bit of lacquer peel under the OS light cluster I had the bumper removed and repainted. The garage did a stunning job BUT.. although they got the paint match perfect on the sides it highlighted that the flat areas of the boot lid and tops of the rear wings have faded slightly resulting in a slight colour difference. I asked him could it be solved by painting them but he says it will only highlight other faded areas and before you know it the whole car will be getting done.
Most days it doesn't bother me.... but somedays Im mentally writing a cheque for a top quality respray.
His advice: Leave it alone as it doesnt warrant a full respray.
Has anyone else had a similar problem?
Old 07-10-2017, 05:45 PM   #13
NewArt's Avatar
Nobody will see it but you!
Old 07-10-2017, 08:15 PM   #14
Something about german cars painted yellow. The paint seems to fade at different rates and after a few years it looks like the car was painted with 3-4 different yellows. The bumpers are usually the first to change.
Woody
Old 07-10-2017, 08:57 PM   #15
AZ986S's Avatar
Your cat looks bored
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 07-11-2017, 11:46 AM   #16
Yeah, my bumpers on the yellow peril have faded differently than the metalwork.
Sent from my ONEPLUS A3003 using Tapatalk
RichRobby is offline   Reply With Quote
Old 07-13-2017, 12:16 AM   #17
Its still worth it to have the speed yellow colour tho lol
