Old 06-15-2017, 07:37 AM   #2
Check you cables, one or both of them may need adjustment.
This happens from time to time. It is usually on the gearbox side of the cable, they will some times fall off of the carrier, or get loose.
If you have already checked this then it could be more extreme of a issue, but this is where I would start.
Erik Johnson
(720) 899-6005 phone
Erik Johnson is offline   Reply With Quote
Tags
first gear , gear , linkage , slip , transimssion
