Old 05-19-2017, 07:43 AM   #1
Registered Abuser
New muffler with custom exhaust
First of all, I realize that my 2000 Boxster S no longer has the original engine... but the exhaust that I made can easily be adapted to almost any 986 setup from the axles back.
Having a non-conventional engine in my Boxster, there are no off-the-shelf solutions for exhaust systems. Even if I tried to use an existing Porsche muffler, it's not very conducive to higher HP / bigger engine displacements. I needed a true dual 2.5" system for my application.
My proof-of-concept exhaust was a simple pair of cheap glass packs that I welded to some old mandrel bends I had laying around the garage. It worked OK, but the placement of the mufflers had them rubbing against the trans-mount cross member. It was tight. Really tight. Additionally, it was loud. REALLY loud.
I wanted to incorporate some form of an X-pipe or crossover pipe, so I went looking for dual inlet / single outlet mufflers. Almost every style of 2-in / 1-out muffler was configured for a longitudinal (front to back) setup. There clearly wasn't enough room for this style.
However, I found a muffler that I believe was originally designed for a Mitsubishi EVO that which might fit the bill. It's intended to be a 3" single inlet with dual 2.5" outlets... but is also a perforated tube design meaning I should be able to run it backwards with no compromise in flow.
https://smile.amazon.com/gp/product/B0031TQE84/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
To get this to fit, I was going to need some mandrel pipe bends. I found this deal for a huge assortment of mild steel pipes. Sure, stainless would look better... but is also twice the price and I'll be painting the pipe with high temp ceramic paint when I'm done anyway.
https://smile.amazon.com/gp/product/B01I47IEY4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
The fitment of the muffler in the Boxster is "good". I wish it tucked up underneath the bumper another inch, but I'm otherwise happy with it. I did have to trim a very small section of lip from the inside of the bumper skin (you'll never see if from outside the car) but that's mostly because my transmission is set back an additional 1.5". A stock located transmission shouldn't have this problem. I also decided to angle the tip downwards about 15-20° to help tuck it up higher under the bumper.
Running the pipes was pretty straight forward once I committed to a plan. I used two of the 180° bends and two of the 90° bends that came with my pipe kit. I did cut up two short sections of the old exhaust (those are the grey pieces) to get the smaller bends I needed.
For ease of installation and maintenance reasons, I use a band clamp between the 180° and 90° bends.
Additionally, you may notice that I do not have any flex pipes in my design. Since all of my exhaust points are mounted to either the engine or transmission, I technically don't need any flex joints. Would I like a flex joint for added piece of mind? Yes. Did I have the space or patience to add one in? No. It was a beautiful week and I just wanted to get this done so I could go driving.
Time will tell if I actually need to add a flex joint or not.
Finally, here is an A / B comparison between the two exhausts. The cell phone obviously doesn't capture the true loudness of the old system (thank you heavy compression algorithms) but the new system is quite a few less dB overall.
https://www.youtube.com/watch?v=V3jZ5SnlU-4
Hope you enjoyed it.
Bayley is offline   Reply With Quote
Old 05-19-2017, 04:27 PM   #2
WillH's Avatar
I did enjoy it. Do you have any db readings on it?
Old 05-20-2017, 02:28 AM   #3
fridsten's Avatar
This is interesting. But what engine do you have installed?
fridsten is offline   Reply With Quote
Old 05-20-2017, 04:08 AM   #4
WillH's Avatar
https://www.amazon.ca/Vibrant-Performance-10633-Muffler/dp/B00LF4VV80 is better sized for us running the flat six. Two 2.25" in one 2.5" out with the same body size. The extra 1.5" space not running a v8 and a bit more angle should help with fitment. Twice the price of the magnaflow dual/dual I thought I would eventually buy for the crossover, but less fabrication after for the tailpipe.
From the limited reviews I've found they seem to be quality mufflers.
@ Bayley
Fitment does look tight, has the car been on the road? Any contact between the muffler and the bumper cover when things start moving around. Are you worried about heat transfer to the transmission the way you have it mounted or melting the bumper cover?
Old 05-22-2017, 07:57 AM   #5
Registered Abuser
Originally Posted by WillH View Post
@ Bayley
Yes, I've got maybe 25-30 miles so far. I'm fighting a moderate oil leak at the moment from what I suspect is a crank position sensor that's slowly failing... but that's another story.
The muffler clearance is tight, but I don't see any signs of interference or heat getting into the bumper skin. I'll keep an eye and update after I've got a few more miles.
I'm not overly concerned about heat from the muffler getting into the transmission. Yes, there will be some... but I'm skeptical that it's enough to be concerned about. I might add a phenolic spacer of sorts at a later time. TBD.
Old 05-22-2017, 07:59 AM   #6
Registered Abuser
It's a Chevrolet Gen III small block (first generation "LS" engine). It originally came from a 5.3L Silverado pickup, but has since been significantly modified to output ~450 hp. The engine is all aluminum and weighs about the same as the original 3.2L
Old 05-22-2017, 10:16 AM   #7
That sounds awesome mate, do you have any drone with the roof up.?
Dualist is offline   Reply With Quote
Old 05-22-2017, 12:50 PM   #8
Registered Abuser
Thank you.
I'm not going to sugar coat it, the exhaust does indeed drone. Top up or down, you can definitely hear it. It's substantially better with the new muffler though. The old system was almost painful at times and conversations with a passenger were almost impossible. I can actually listen to the radio now with the new muffler.
Old 05-25-2017, 09:07 PM   #9
Very interesting find on the vibrant muffler - thanks for sharing. I wonder if the internal construction is a "T" or a "Y". Shipping weight is listed at a bit under 20 lbs. An actual weight would be helpful.
If anyone tries this on a stock Boxster engine, it would be interesting to hear how it works.
2001 Boxster
Old 05-26-2017, 05:21 AM   #10
Nice! The new muffler gives it a more European sound. Not that there's anything wrong with a lumpy American sounding V8. Just not in a Boxster
Woody
Old 05-26-2017, 06:22 AM   #11
Registered Abuser
I'd say it weighs closer to 15 lbs. It's not a feather weight, but it doesn't feel as heavy as my kid's bike.
Internal construction is a very mild "Y" design. The pipe between the two 2.5" holes is straight through design with a mild "bump" to help divert airflow from (now 'to') the 3" port.
Check out mah mad Paint skillz for an example, y0!
Thank you. I will say that is sounds a lot better than it did when I bought the car:
"Clank - Clank - Clank - Clank - Clank - BANG! - BANG!- BANG! - wrapwrapwrapwrapwrapwrap - hissssssssss"
And no, it wasn't the IMS. The entire crankshaft broke in half.
Old 05-26-2017, 10:27 AM   #12
njbray's Avatar
That sounds good - almost like a Lambo.
I hope someone tries this on a stock motor. Who's going to be the guinea pig?
Just a case of figuring out the support brackets. It's a good price too.
Old 05-30-2017, 02:36 AM   #13
I like the sound. Any hp gain with your exhaust setup?
fredd5r is offline   Reply With Quote
Old 05-30-2017, 06:26 AM   #14
Look similar to my set-up in size terms. I have 2 silencers per side though with 5x12 into 8x14 chambered silencers at the rear which lead to 2 3.5" tails. Makes it sound a lot deeper than stock.
That986 is offline   Reply With Quote
