08-05-2015, 09:26 PM
#1
How do you polish headlights?
Hello all,
This is mainly directed at Charles (Particlewave) because I've seen his work, but anyone can chime in.
How do you polish a set of headlights, and how do you UV protect them?
I know the basic steps: sand the big stuff out, use progressively finer grit polish. What grit do you use to sand? What polishes are you using?
Tony
Lapis Blue 03 Boxster S
08-05-2015, 09:40 PM
#2
Mild to moderate yellowing and light scratches can be polished out with a one-step process using Meguiars Plast-X polish and a terry cloth or wool bonnet. I use terry cloth and a 6" random orbit buffer.
Only wet sand if absolutely necessary.
New UV coat is trickier. There are a lot of off-the-shelf options and as many opinions. Most consumer products are very temporary and will need to be re-applied every month or two, depending on how much sun your car sees. The best UV coats require sanding the old finish off completely and use of a UV cure light (which I don't even have).
That's really best left to a pro. I've only had limited success with complete restoration and only on my personal headlights.
I generally stick to polish and it does make a significant difference.
08-06-2015, 02:36 AM
#3
Believe it or not, over the years I've used toothpaste and a damp cloth, you'll be amazed by the results achieved, honestly
08-06-2015, 03:40 AM
#4
You can see what I did on this thread:
http://986forum.com/forums/general-discussions/54697-advice-used-litronics.html
I liked the Sylvania kit because of the UV coat they include in the kit. I finished my project in February or March, and I have not yet seen any signs of yellowing. However, I need to note that Particleweave has been on the mark with his advice, so I would not ignore the possibility of yellowing.
I think some folks have tried automotive clear coat as a UV inhibitor, but I do not have any personal experience with that or the toothpaste. The set of headlights I had were in poor condition, so Skoosh1970's method may work well on a pair that are in less need of attention.
08-06-2015, 07:53 AM
#5
Why not buff them nice and shiny and clean and then apply a film over them to protect them from rock chips and UV?
Porsche Boxster (1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004) Headlight Covers
I used this brand on my wife's new ES350 and it's done a great job of protecting the headlamps, you can hardly see its been applied to the headlamps, and after 2 years in the sun it has not clouded or yellowed. Of course, I keep it waxed, but nevertheless... good protection for cheap money.
08-06-2015, 08:52 AM
#6
I spray painted mine with a clear coat. Some also use Minwax Helmsman Spar Urethane. You can apply it by using a lint-free towel, and wipe on with the liquid Urethane.
There's a thread at HIDPlanet about using films. You can buy precut like linked above or by a sheet and cut it yourself:
How to: Clear lens protection on curved headlights (incl 11yr aging result)
08-06-2015, 10:18 AM
#7
Wait, to protect from UV rays, you cure a special coating with.........UV RAYS??
08-06-2015, 12:17 PM
#8
+1 on this. My headlights still look like new.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
08-06-2015, 03:24 PM
#9
I just bought a set off eBay for $400, and I assume they'll need some work. The film idea has some merit.
Sent from my SM-T800 using Tapatalk
08-06-2015, 07:08 PM
#10
I've done lots of headlights. Some pretty bad, like mine were.... Got them looking almost new starting from a heavy grit sand paper to remove all the yellowing, all the way down to 5000 Grit, Then clean with alcohol and clear coat with UV Clear. Looks awesome.
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
08-07-2015, 02:44 PM
#11
Don't think you need to go all the way down to 5k grit. If you are painting the lights (Sylvania clear or Minwax spar varnish gloss). All you need is 400 then 800 and paint. About a 1/2 hour job.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
08-22-2015, 04:26 AM
#12
Beginner
I've done mine 3 times now, and I think I have a working solution that I will use next time.
400 grit wet/dry paper - wet sand with lots of water
then
1500 grit wet sand - lots of water
then
2000 grit wet sand- lots of water
then
plastic polish (from a turtle wax polishing kit)
then
toothpaste
then
prime with turtle wax polishing kit primer
then
seal with turtle wax polishing kit sealer
The sandpaper greatly speeds things up.
I did one headlight with the toothpaste and frankly did it half a$$ed as it didn't seem to be doing much of anything.
Skipped the toothpaste on the other. The result is they look the same, and quite good in the daylight.
At night with the lights on it is strikingly evident where the toothpaste was used or not. With toothpaste the lens is clear with the lights on, without toothpaste there are so many micro scratches the lens looks frosted at night with the lights on. Oh well, I'll get it next time.
2003 S manual
08-22-2015, 08:42 AM
#13
Will try. But is it really the tootiepaste that made the difference between frosted look at night and clear look? Did you also sand that light?
08-23-2015, 04:53 PM
#14
Beginner
Yup. Toothpaste. It's a lot of work by hand which is why I skimped. I noticed a drill run kit at Autozone. When I do it again I've decided to do it that way to reduce manual labor. If I went manual again I'd also start at 2000 grit and get even finer paper as the 400 and 1500 hundred eliminate the yellow fast, but leave sanding scratches that take time to remove.
2003 S manual
08-25-2015, 07:56 AM
#15
09-03-2015, 02:58 PM
#16
2006 987
if they're bad and cloudy, Sam's club will make them look brand new for $30
If you're just trying to maintain crystal clear headlights, Zymol wax works well because it's a cleaner wax so it's a mild polish. Try that every few thousand miles. I usually use a orbital buffer but you can do it by hand.
2006 987 2.7 manual silver/black, PASM, OEM drilled rotors, heated seats
1998 986 2.5 manual black/tan with bad engine = SOLD
09-22-2015, 08:04 PM
#17
Brasso...FTW!
10-11-2015, 12:04 PM
#18
Originally Posted by boxster6354
Will this eliminate those pesky mosquito bites on the headlights as well?
10-16-2015, 04:11 PM
#19
Anyone else remove a film like this from their headlights?
2006 Audi A4 Avant 2.0t Quattro
1997 Boxster Glacier White w/facelift(gone but not forgotten)
2004 Boxster S 550 Spyder Anniversary Edition
10-18-2015, 06:10 AM
#20
I try every few months . I have tried the headlight cleaners among other things and I cant get that damn film off. I bought a orbital polisher a while back I think that's going to be my next option then I will sand if that doesn't work.
