Old 04-06-2017, 08:38 AM   #1
Re-install CDR-210 radio
Happy to be back in the Boxster business after briefly owning a new 2001 986 and then a 1988 911. Recently acquired 1997 986 Guards Red, sorting out some minor issues.
One is replacing junky aftermarket radio with the original CDR-210, which old owner thankfully kept (along with code). Disconnecting the aftermarket, I'm left with 2 plugs, one blade and one yellow, that seem to fit right into the original radio (along with antenna). Plug them in and nothing happens.
There is a blank space in the original radio and I'm wondering if an original plug has been removed and something spliced in for the aftermarket. The blank looks like it needs another black plug--there are also some blank spots next to the yellow plug, but believe that is for CD changer option.
So question is: what plugs should I have to plug into the CDR-210? I can't seem to find an image.
acbprop is offline   Reply With Quote
Old 04-06-2017, 11:27 AM   #2
correction
the two plugs that I have so far--one black, one yellow
Old 04-06-2017, 11:39 AM   #3
I am No. 1348
algiorda's Avatar
I have a CDR23 for a 2004, the yellow goes on the top all the way to right (facing the front of the radio), the black one goes right beneath it all the way to the right. My radio has another connector, but that is for the Fibre Optics, and of course there is the antennae wire. I don't have the CD changer, my CD is built into the CDR23.
The Black and Yellow should be all you need to get the radio working. Check the fuse, you never know what the previous owner did with the radio perhaps the replaced another radio just before they sold it and blew a fuse.
algiorda is offline   Reply With Quote
