Old 02-15-2017, 08:15 AM   #1
Variocam fault code diagnosis with Durametric
Fault Codes P0300+P0301+P0302+P0303 -
Last edited by Gelbster; 03-08-2017 at 07:19 AM. Reason: Incomplete due to 15000 char limit
Old 02-15-2017, 09:08 AM   #2
Having just completed this project, including removing the actuators to replace the pads (or brakes as I think Porsche calls them) this is all very good information and helpful to have in one location. I ended up making my own special Porsche tool 9624 and cam retainer tool and LH threaded rod tool for compressing the actuators. I ordered the LH parts a few weeks in advance of needing them so not a problem for me to wait for oversees shipping. The tools are not difficult to fabricate but ordering the tool kit would make things easier. I had time so I thought I would try and make the tools in advance while waiting for some parts to be delivered to get the project going.
It really is tight on bank 1 and it would have been easier with the cat removed but I just made it work. Some of the 23 bolts on the cover can best be accessed from topside as well. Doing bank 2 next I was relieved to have the additional access. I used the Porsche OEM Loctite 5900 sealant for the cam covers and removing the old sealant was a chore. I found out that you can't just go to the autoparts store and buy gasket remover anymore (at least in my area) so I had to order it online and wait for the shipment. I used the remover and a plastic scraper so as not to damage the aluminum surfaces for resealing.
Thanks Gelbster
dsallean is offline   Reply With Quote
Old 02-15-2017, 11:27 AM   #3
You are welcome. It is good to get confirmation from someone else who has done the job !
What was your problem(s) and how did you solve it?
I ask because this job can be much more expensive than an IMSB replacement if you make some mistakes in diagnosis and testing. I don't mind buying the parts from Pelican but it is humbling if you discover they were unnecessary.
Old 02-15-2017, 11:47 AM   #4
My camshaft deviations were off on both banks and beyond spec on bank one. So it appeared the actuator pads needed replacement. I was also getting some pad material in the oil filter in addition to a lot of green material indicating an actuator was failing. So I replaced the actuator, pads on both banks and new a new chain for each bank. I got the parts from Pelican except for the actuator. I went with a low mile used unit instead of $1,000 for a new one.
I think the hardest part of the job is doing it with the engine in the car. If it was on a stand this would be much easier.
Old 02-15-2017, 04:10 PM   #5
Mine is up on a lift but even so I removed the deck lid and the trunk lid ! This would be a miserably frustrating job in anything but prefect conditions.
