Old 08-06-2016, 02:31 AM   #1
Axle Boots, Disconnect What?
So, looking at the job, you would just need to disconnect the UJ from the Trans, then remove it, right? Then slide the new boots down to the wheel end, and replace the trans end after re-attaching the UJ and torquing it back to the trans? No Need to remove the axle bolt at the wheel, correct?
SilverSSS is offline   Reply With Quote
