Old 05-05-2016, 04:07 PM   #1
Ben-Auto-Design
Ben006's Avatar
DIY Manual radiator fans control
Hi guys!
I've wanted to do this for a while, and finally did it!
A manual control of the radiator fan, nothing new, but I didn't find any "good" DIY for it... I'll do my best.
I wanted it to be plug and play, without messing any original part, and without any soldering inside the car.
So here is what I used:
-These relay sockets (actually I just found those... half as much of what I paid!):
Amazon.com: Absolute USA 5-Pin 12 VDC Interlocking Relay Socket, 5 Set: Car Electronics
-Some 14AWG wire, you can find here: Electrical Wire/Primary wire 85732R- ReadReviews onElectrical Wire #85732R
-Those male quick disconnect terminals: Tyco Electronics 250 Series 16-14 AWG 10/Clam Male Disconnect Fully Insulated Nylon-CPGI-3-520107-2-10 - The Home Depot
They are the thickest I found.
-A 3 positions switch: CARQUEST by BWD Multi Purpose Switch URS83: Advance Auto Parts
And you'll need a soldering iron (the 18w one at Home Depot is pretty good), heat shrink and solder.
Here is the final part:
Hard to see anything with all these wires...
What we want is a mean to ground the pin 85 of the 4 fan relays manually.
This is done with the three positions switch, one position for low, one position for high, and the middle position is off.
The PCM still controls the fans, and even if you forget to turn the fans off, they will shut off when you turn the key off after 5sec.
Two relays are for high speed and two are for low speed (and I just realized that on the picture I got the wires wrong!)
You can do the ghetto version by simply wrapping a wire around the pin directly on the relay... but I don't like it!
I measured 11.5A at high speed and 7.8A at low speed when the car is stationary. 14AWG should be alright for that.
The relay are positioned like this from right to left: [low speed right] [high speed right] [low speed left] [high speed left].
I replaced the wires going to the pins 87 and 30 with the 14AWG wire since the are the power wires, the other are only for control (low current).
I'll draw a clear schematic after... pictures are pretty useless here.
I hope it helps!
I haven't put the final assembly in the car yet.
Ben
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 05-05-2016, 04:38 PM   #2
Ben-Auto-Design
Ben006's Avatar
Here is the least crappy I could do in 10min:
1982 928 S Euro
Old 05-05-2016, 04:52 PM   #3
01101
Hey, careful with that last hosting site, I don't know if i clicked something by accident, but its got some security issues.
alm001 is offline   Reply With Quote
Old 07-26-2016, 09:12 AM   #4
steved0x's Avatar
I just went to it to view the pic, no issues. I clicked the pic to get a closeup and it opened in a new tab. When I closed it, it took me back to the original tab, which now had a selection of lovely ladies for me to choose from... Luckily they were SFW.
Old 05-05-2016, 04:57 PM   #5
Ben-Auto-Design
Ben006's Avatar
casimages.com ?
I've used it for years without issues :/
1982 928 S Euro
Old 05-05-2016, 05:16 PM   #6
There Is No Substitute.
rick3000's Avatar
Great job! I really like that it is fully reversible, I might do this over the summer.
To clarify, basically those male disconnects get plugged into the relay board instead of the relay, then you plug the relays into the added interlocking sockets, with pin 85 wired to the switch to manually override the fans?
It would be great if there was a way to clean up all the male disconnects, but it doesn't look like anyone makes a male relay plug, unless you want to gut a standard relay.
Old 05-05-2016, 05:22 PM   #7
Ben-Auto-Design
Ben006's Avatar
I have spare relays that are waiting to get destroyed for the sake of DIY's
And yes, that's exactly it, you plug the quick disconnect terminal instead of the relays. and the relays into the interlocking sockets.
I have to get a glue gun so I can lock the wires inside the sockets once for all.
1982 928 S Euro
Old 05-05-2016, 05:25 PM   #8
rick3000's Avatar
I really love this, my 986 does not like the summer heat, so I will probably do this. Although I may just use fuse taps (a slighter fancy solution than wrapping a wire around the pin), then see if I can wire it to an OEM switch. I still have two button blanks to fill.
Old 05-06-2016, 10:17 AM   #9
Ben-Auto-Design
Ben006's Avatar
I opened a relay today...
I have to test it ! the base with prongs should be reusable
The problem with using the OEM switches is that they are one stable position, not 3 like the one I use, so to have control for high and low speed, you'd have to use to more relay and two switches!
1982 928 S Euro
Old 07-26-2016, 11:19 AM   #10
Ben-Auto-Design
Ben006's Avatar
Ahah, did you choose one?
It's weird it always works with me... maybe adblock is blocking the pop-ups efficiently!
1982 928 S Euro
