Old 02-24-2016, 04:48 AM   #1
New Porsche Fan
imari's Avatar
Headlight Removal
Quick question:
I need to remove my headlight but do not have the actual 986 headlight tool. Does any have a recommendation on what I could use in place of that? size, hex key, etc???? I need something that I can pick up at Lowes, Auto Zone, etc. Thanks!
2001 Black Boxster
2004 Red Vespa 150cc
2006 Black Maserati QP
2008 Black VW Eos
2010 Charcoal Ford Flex
imari is offline   Reply With Quote
Old 02-24-2016, 05:26 AM   #2
98 Arctic silver 986
tommy583's Avatar
Its a 4 or 5mm socket. Just put it on an extension and use a ratchet.
Old 02-24-2016, 05:54 AM   #3
New Porsche Fan
imari's Avatar
Thanks Tommy583...I'll try that.
2001 Black Boxster
2008 Black VW Eos
Old 02-24-2016, 06:25 AM   #4
5mm (i think)
I belive it's a 5mm.
Sassmatt72 is offline   Reply With Quote
Old 02-24-2016, 08:59 AM   #5
2003 Base 5-speed
grc0456's Avatar
Ditto.
Old 02-27-2016, 03:34 PM   #6
New Porsche Fan
imari's Avatar
Thanks guys...it was 5mm. Got the new headlight installed in minutes.
2001 Black Boxster
2008 Black VW Eos
Old 02-27-2016, 05:23 PM   #7
You got a good solid click?
locked in flush?
Old 02-28-2016, 05:12 AM   #8
New Porsche Fan
imari's Avatar
locked in flush?
Yes, I heard the "click" and it's flush. I only worry a bit because the previous one flew out during hard braking and I definitely don't want that to happen again. Is there any recommendation for an additional step to secure it in the event that I slam on the brakes one day????
2001 Black Boxster
2008 Black VW Eos
Old 02-28-2016, 07:30 AM   #9
time to get creative....
If it's a real concern to you (as it should be after having happened once),
I'd open the wheel well liner and attach something to the back of the light from there...
I did that to connect my wire plug (since it's cracked and will not plug in on it's own.)
good luck.
matt
Old 02-22-2017, 08:06 AM   #10
gomarlins3's Avatar
The replacing of my burned out low beam bulb was ridiculous easy. I think it makes up for the process to change the engine air filter. Maybe not....
gomarlins3 is offline   Reply With Quote
