-   -   Headlight Removal (http://986forum.com/forums/diy-project-guides/60552-headlight-removal.html)
imari 02-24-2016 04:48 AM
Headlight Removal
Quick question:
I need to remove my headlight but do not have the actual 986 headlight tool. Does any have a recommendation on what I could use in place of that? size, hex key, etc???? I need something that I can pick up at Lowes, Auto Zone, etc. Thanks!
tommy583 02-24-2016 05:26 AM
Its a 4 or 5mm socket. Just put it on an extension and use a ratchet.
imari 02-24-2016 05:54 AM
Thanks Tommy583...I'll try that.
Sassmatt72 02-24-2016 06:25 AM
5mm (i think)
I belive it's a 5mm.
grc0456 02-24-2016 08:59 AM
Ditto.
imari 02-27-2016 03:34 PM
Thanks guys...it was 5mm. Got the new headlight installed in minutes.
Sassmatt72 02-27-2016 05:23 PM
You got a good solid click?
locked in flush?
imari 02-28-2016 05:12 AM
locked in flush?
Yes, I heard the "click" and it's flush. I only worry a bit because the previous one flew out during hard braking and I definitely don't want that to happen again. Is there any recommendation for an additional step to secure it in the event that I slam on the brakes one day????
Sassmatt72 02-28-2016 07:30 AM
time to get creative....
If it's a real concern to you (as it should be after having happened once),
I'd open the wheel well liner and attach something to the back of the light from there...
I did that to connect my wire plug (since it's cracked and will not plug in on it's own.)
good luck.
matt
gomarlins3 02-22-2017 08:06 AM
The replacing of my burned out low beam bulb was ridiculous easy. I think it makes up for the process to change the engine air filter. Maybe not....
