Old 09-26-2024, 07:53 AM   #41
Quick update: these are still working out really well. The car feels tighter than before and I think it reduced some of the vibration I was getting at 75-80mph. And for a Porsche project, it was almost too easy 😆
Originally Posted by Danimal View Post
I had the classic clattering in the back going over rough ground at low speeds. So I changed the rear trailing arms with the 987 TRW part listed in this thread. It is much cheaper than the corresponding 986 part from TRW.
I did it with the whole car up in the air using lift bars. Had no problem aligning the bolts, just had to push a little on the lower control arm. I used the existing bolts and torqued them to spec (118ft/lbs). I did not use loctite but sort of wished I did. Oh well.
Took it on two test drives and the clatter is gone. Still can’t figure out what was wrong with the olds ones. But glad the commotion is gone 👍
Another great fix from the forums in the books! 📕
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
Old 04-30-2025, 04:14 PM   #42
lkchris's Avatar
[QUOTE=911monty;479191The reason it is installed with the nut on bottom is so that if the nut were to fall off, the bolt would still be in place. With nut on top if nut falls off bolt also falls out.[/QUOTE]
Theory is correct, but nevertheless factory installs them with nut on top … and plenty of thread locker to keep it from coming loose.
New factory bolts do not arrive with pre installed thread locker, so apply some when replacing.
There is factory applied thread locker on the front end bolt, too. Theory would have it, you chase the threads on captive nut to remove old sealant first.
I’d use new nuts and bolts for this job. Just good practice and also saves cleaning off old thread locker.
Kent Christensen
Albuquerque
2001 Boxster
2012 GL550, 2010 CL550
2 BMW motorcycles
Old 02-02-2026, 08:40 AM   #43
I am going to replace my rear control arms on my 2000 Boxster S. I notice in this video, the guy does it on a lift with the wheels still on. I have a lift and ramps. Being in California, I'd much rather do this with the lift or ramps and not jack stands.
Will the upper link and the drive shafts hold the suspension together? Or will this risk the suspension spreading and falling?!!!
https://www.youtube.com/watch?v=AGEn7M2Sa8o
Jay Laifman is offline   Reply With Quote
Old 02-02-2026, 02:32 PM   #44
Ah, I watched the video again more closely. This time I caught that they had a jack in there:
