Old 12-07-2015, 10:27 AM   #1
Exterior door handle drivers side not working
Hi all first post - any tips for getting the door handle off. I have just removed interior panel and foam. I think I can see a broken / parted wire? but the access seems very poor. Cant find anything on youtube. Its a 2000 Boxster S.
Boxster Bandit is offline   Reply With Quote
Old 12-07-2015, 10:38 AM   #2
steved0x's Avatar
I've never had that particular door issue but this article might help:
Not the door lock assembly part but the steps to access the external door handle. The article before this one has some info too.
Porsche Boxster Door Lock Mechanism / Door Handle - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 12-07-2015, 10:43 AM   #3
Thanks Steve - I didn't realize that the inside metal comes off (I haven't removed all the foam - only the corner near the lock! )
Old 12-22-2015, 12:00 AM   #4
Problem Solved
Small threaded bar had jumped out of plastic retaining clip because the securing pin behind the handle was rusty. Replaced all for £30 now works but Airbag light on!
parts 9 10 11 and 12
Tags
door handle
