Old 09-06-2015, 12:16 PM   #1
Porsche9's Avatar
Where is the AC drain line?
I'm trying to clean out my AC drain line as I'm getting the moldy smell from my AC and I don't see water under the car after running the AC. The problem I'm having is actually finding the drain line. With only about 8 inches of lift from my ramps I'm looking at everything within a few inches of my face laying on my back. I found the line for the fuel overflow but no AC line. Do I need to remove the plastic pan to see it? Based on the diagram attached it should right where I'm looking. Any help is appreciated. Thanks.
http://i167.photobucket.com/albums/u121/frankboxster/NewPicture.png
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 09-06-2015, 01:36 PM   #2
It is directly under the heater box.
Old 09-06-2015, 02:24 PM   #3
still plays with cars...
BoxsterSteve's Avatar
Would a blockage cause
water to back up and drip on your feet & ankles while the AC is running?
Six speed 2000 Boxster S
Old 09-06-2015, 10:36 PM   #4
Porsche9's Avatar
Yes. I've had a few drops hit my fit while making some quick left hand turns.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 09-06-2015, 10:37 PM   #5
Porsche9's Avatar
Am I going about it wrong by trying to get to it from under the car?
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 09-06-2015, 11:11 PM   #6
thom4782's Avatar
Yes, I think its best done from inside.
IIRC if you peal back the carpet from the front and center of the passenger foot well, you can see where the tube runs from the AC/heater box through the floorboard. I believe you can simply pull it out on both ends and clean it.
There may be residual water in the box the comes out when you pull out the tube so put some absorbent material down before you disconnect it from the box.
Old 09-06-2015, 11:35 PM   #7
Porsche9's Avatar
I'll give it try in the morning. Thanks.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 09-07-2015, 08:17 AM   #8
It is best done from underneath by blowing low pressure air through it, never using a wire or any other solid object to push through it. Also, do not pull on it, if it becomes dislodged from the heater box, it can be difficult to reconnect.
Old 09-07-2015, 08:45 AM   #9
JayG's Avatar
I get that from time to time when its hot and humid. I found it to be condensation on the air vent tube
YMMV
Old 09-07-2015, 12:57 PM   #10
Porsche9's Avatar
Thanks JFP. I went under the car and can't find the drip line for the AC. I found what I believe is the fuel overflow drip line in the first photo but not the AC drip line. Do you have to remove the under body pan to find it?
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 09-07-2015, 03:05 PM   #11
It should come through, but may have been inadvertently blocked behind one of the belly panels when it was removed previously.
Old 09-07-2015, 04:13 PM   #12
Porsche9's Avatar
I guess it's mean getting on my back and removing the belly pan. Thanks.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
