Old 04-29-2015, 09:29 AM   #1
oil fill tube
I replaced my middle fill tube which had developed a hole and cause a vacuum leak. The joint is now leaking oil. It was very difficult to reconnect the new middle tube to the old engine mounted fill tube.
Any ideas on sealing the leak at that oil fill tube joint? Thanks.
2000 base 2.7 Boxster
rem503 is offline   Reply With Quote
Old 04-29-2015, 09:35 AM   #2
Need For Speed
KRAM36's Avatar
Should be a spring clamp where the fittings meet. Is it on there?
2003 Boxster S
Old 04-29-2015, 12:32 PM   #3
Spring clamp is in place. There was a fabric band in the old joint. I reused it as best I could. It was near impossible to connect the new tube to the old tube.
Old 04-29-2015, 03:45 PM   #4
Need For Speed
KRAM36's Avatar
I had to take mine apart. I don't remember any piece of fabric at the joint?
2003 Boxster S
Old 04-30-2015, 02:24 AM   #5
oil fill tube
Mine had a narrow mesh-like thin strip in the joint. I left it out on my initial attempt to rejoin the two tubes because so much force was needed to reattached the tubes. The joint leaked. So I thought the fabric was a type of gasket. I reassembled the joint with the fabric and it still leaks.
Old 04-30-2015, 08:58 AM   #6
Don't recall any fabric on mine either. Bare plastic IIRC.
Old 04-30-2015, 05:33 PM   #7
I used a screwclamp and that stopped the leak. Be sure you get the clamp in the slot on the pipe. Its hard to see.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 05-01-2015, 04:50 PM   #8
oil fill tube
I replaced the spring clamp with a screwclamp in the joint groove. I'll monitor the leak and report back. Thanks.
