Old 04-27-2015, 07:18 AM   #1
Help--seat bottom
Hi guys,
Need help. While taking out seat to recondition the passenger side leather, a rubber tube dropped out and I didn't see where it came from. It's 15-18 inches long with metal pieces protruding from each end about 1-2 inches long. Anyone have any idea what they are and where they go? Could they go into the top of the seat motors? What do they do? Thanks, Larry
022520 is offline   Reply With Quote
Old 04-27-2015, 11:59 AM   #2
If you post this in the "General Discussions" forum, you'll probably get more responses than you would in the "DIY Project Guides" forum
Also, a picture would help.
Seat back release cable?
Height adjust cable?
Lumbar support pneumatic tubing?
Seat rear adjust drive shaft?
Old 04-28-2015, 06:16 AM   #3
You are a life saver
Your illustrations showed me exactly where it goes. It's on the bottom not the seat backi. It's #5 in the fourth illustration. Not sure what it does but at least I know where it goes.
Any idea what it does?
Thanks, Larry
Old 04-28-2015, 08:59 AM   #4
No problem.
It appears to be the seat back position adjust drive cable.
Here is the link for the parts catalog (illustrations showing every last nut and bolt).
986_USA_KATALOG.pdf
