Old 04-29-2017, 06:30 PM   #181
Did you test both doors?
Old 04-29-2017, 06:54 PM   #182
Swhitcomb's Avatar
Yes. Tomorrow I'll shoot a video and show you what alarm is doing.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Swhitcomb is offline   Reply With Quote
Old 04-30-2017, 05:45 AM   #183
Originally Posted by Swhitcomb View Post
Well, the new mechanism came from Woody this week, and I finally had the time to install it today. The CLU still doesn't unlock after the alarm has armed. About 29 seconds after it's locked. It does however, now roll the windows up and down with the key like it should. Have to keep digging.
what model no. Is your immobiliser as I have the exact symptoms. Had to reverse polarity on the keyfob to get it to unlock/lock but as soon as immobiliser kicks in nothing. Key only opens drivers door until I put key in and turn ignition on then I can use key to unlock rest of the system or remote
Craig030774 is offline   Reply With Quote
Old 04-30-2017, 07:05 AM   #184
Swhitcomb's Avatar
M535. The key fob will lock and unlock the car fine for about the 1st 30 seconds. Then when the alarm arms it won't do it anymore. However, when you press unlock, it does light the door lights and the dash lights. When you unlock it manually with the key and open the door the alarm goes off until you turn the ignition on.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 04-30-2017, 09:34 AM   #185
Swhitcomb's Avatar
That's the long list of codes my immobilizer is throwing. Durametric won't clear them so I have no idea which ones are still an issue, and I don't have access to durametric. I had my Indy shop pull the codes the last time they worked on it.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 05-01-2017, 06:51 AM   #186
What sticks in my mind is that we both have the exact same issue and that we have to reverse polarity on the lock / unlock. If you sit in the car with and open all the doors do they lock as soon as you start the car mine does ( not sure if it's supposed to though )
Old 05-01-2017, 09:40 AM   #187
Swhitcomb's Avatar
Do you also have an M535?
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 05-01-2017, 10:28 AM   #188
No mine is a m543 looking at the wiring diagram and am wondering what and why are the key contacts reversed
Old 05-01-2017, 10:29 AM   #189
only drivers door has key
Old 05-01-2017, 10:36 AM   #190
So, you have the same behavior with the new immobilizer, Craig?
That points to something on the car being wrong. Probably door latch issues. I still think you both have bad door latches (probably on both doors).
Also, the connectors in the door frames are known points of failure. Moisture can get in and corrode the pins/sockets. They can be cleaned with contact cleaner.
Old 05-01-2017, 11:36 AM   #191
yes same issues with new immobiliser not had chance to dig any further with car other than test that I get an earth at clu when turning key for lock/unlock
Old 05-01-2017, 06:51 PM   #192
Swhitcomb's Avatar
I haven't taken the passenger side apart yet, but the drivers side on my car wasn't corroded at all.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 05-02-2017, 01:13 PM   #193
Does every one else's lock as soon as you turn ignition on
Old 05-02-2017, 04:27 PM   #194
Swhitcomb's Avatar
I've never noticed. I'll have to check.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 05-05-2017, 10:15 AM   #195
Spoken to a couple of owners and theirs does not lock as soon as you turn ignition on. Also mk4 golf share same locks as early boxster however not confirmed this
Old 05-05-2017, 11:08 AM   #196
Swhitcomb's Avatar
I can confirm it is a VW part. It has a VW of France stamp right on it. I don't think it's a MK4 part though, they wouldn't have a window drop switch.
Also, my car does not lock when the ignition is turned on, but it does lock itself while being driven.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 05-05-2017, 11:18 AM   #197
Swhitcomb's Avatar
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 05-07-2017, 02:47 AM   #198
Is there a part no. That you can cross reference as the golf ones are £18 brand new
Old 05-07-2017, 05:47 AM   #199
Swhitcomb's Avatar
Did some googling. It's not the same. Very similar though. I found this:
VWVortex.com - MKIV door locks explained - why you're having problems!!!
The mechanism I replaced is still sitting on my workbench, so I took it apart. Tested all the microswitches in it, and they all worked fine. The circuit board is covered in some sort of orange glue. My guess would, it was a fix VW rolled out to address exactly what he found. Broken solder connections. For fun I'm going to resolder the whole board and test it. What could it hurt? May do the same on the passenger side.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 05-07-2017, 12:32 PM   #200
Well that's 1 issue cleared locking doors when ignition on is a dealer option
