Old 05-07-2015, 04:34 PM   #41
Yes Sir. On Renntech a guy had the same problem and he said he took in into the dealer and they had to recode the ECU an it worked after. I am obviously trying to avoid that if possible.
Here is that thread.
Rear Trunk Release Not Working on Remote - 986 Series (Boxster, Boxster S) - RennTech.org Community
antny is offline   Reply With Quote
Old 05-07-2015, 05:24 PM   #42
Registered Boxster abuser
healthservices's Avatar
Yes you can add the 3rd party keyless remote like particle wave and I did. I actually cut the blue black wire away from immobiliser
Old 05-07-2015, 05:41 PM   #43
You cut it away from the immobilizer and wired it direct to the aftermarket unit directly?
Old 05-07-2015, 05:57 PM   #44
Well I used a relay as the first aftermarket unit could not take the load (it fried) and I did not want the immobilizer to be in harms way. second one I used a relay and no issues. Some of the units like particlewave bought have a relay inside and can take a load, I just did not want to chance it.
Old 05-07-2015, 06:08 PM   #45
I just ordered the one you bought. Can you give me any help on what relay to buy and how to wire it? I have ever installed relays in all the things I ever have done with cars.
Thanks bud.
Old 05-07-2015, 07:33 PM   #46
Not a problem. Pretty much standard relay. That can be bought. I just happen to have one. But will find one online so you can see
Sent from my SM-T310 using Tapatalk
Old 05-07-2015, 07:40 PM   #47
Like this one
alarm relay | eBay
But just look up alarm relay and look for one that looks like that, get one with a pig tail so you don't have to source a bunch of wires and connectors.
Old 05-07-2015, 08:36 PM   #48
Dumb question again. Which wires go to what on the relay?
Old 05-07-2015, 08:38 PM   #49
delete this one
Old 05-07-2015, 08:43 PM   #50
try this one instead...
87 jumps over the red wire it does not connect to it.
Old 05-07-2015, 09:01 PM   #51
I actually have an identical relay to his one you posted. So let me break this down because these diagrams make my eyes cross lol.
Cut the blue black wire from the immobilizer.
Connect AM trunk wire to the blue black wire and connect to pin 85
Connect 86 pin with a tap to the red wire
Connect pin 87 to the blue and wire
Ground pin 30
Did I get that schematic correct?
I really do appreciate it the help. I can and have done almost every other thing about working on a car and never have wired a relay lol.
Old 05-07-2015, 09:14 PM   #52
Its funny how some of us are visual and others are not. Which can be a good thing
Old 05-07-2015, 09:26 PM   #53
lol that is true. I am visual on 99 percent of things besides electrical stuff. Wiring diagrams confuse the ever living hell out of me lol.
Old 05-07-2015, 09:27 PM   #54
Cut the blue black wire from the immobilizer. leave immobilizer end disconnected, connect the other end to door lock signal wire from keyless entry
In the trunk....
Connect the unconnected blue black trunk wire to 85
Connect the unconnected blue black trunk wire from actuator to 87
Ground pin 30
Connect the red wire.
Old 05-07-2015, 09:30 PM   #55
Perfect. Thanks bud you have been a life saver on this one. Maybe my only complaint on the car will go away now.
Old 05-07-2015, 09:38 PM   #56
With these cars there always something that can be improved or fixed. Its just... when do we stop?
Old 05-07-2015, 09:52 PM   #57
NEVER!!!
Nothing left to fix on mine, but I'm always looking for things to tweak or improve.
This keyless entry was one of my favorite mods due to ease and usefulness. My "hand activated" storage shelf lights are a close second. Of course, I'm quite fond of the headlights and side markers, as well.
Just...can't...stop!
Old 05-08-2015, 04:55 AM   #58
Nine8Six's Avatar
Prefer the hand activated cubby light mod Have to say that keyless mod is pretty cool too. Changing dash & accessories lights colors etc... but the best of all, the de-ambering the egglights. Now that my man (speechless)
Sure I forget a few others. Kewl mods, never stop.... keep then coming Charles
Regards
A fan
Old 05-08-2015, 09:22 AM   #59
What? You don't like my http://986forum.com/forums/general-discussions/50640-%247-custom-leather-interior.html
Thanks Fred! You're still #1, pal!
Old 05-10-2015, 05:29 AM   #60
Swhitcomb's Avatar
Question for you guys. When you connect the new unit to to lock wires, do you leave it still connected to the immobilizer, or disconnect it? I'm considering doing this on my 02.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Swhitcomb is offline   Reply With Quote
