Old 06-09-2015, 04:07 PM   #101
Pdwight's Avatar
Got that
I haver the assembly out of the car, getting the new metal assembly into the plastic cradle is the problem
Old 06-09-2015, 04:34 PM   #102
Ben-Auto-Design
Ben006's Avatar
the two red parts on this picture right ?
they should slide in with a tight fit but without much trouble.
Can you tell me how you did ? the buckets first then the shifter or the other way ?
Ben006 is offline   Reply With Quote
Old 06-09-2015, 07:24 PM   #103
Pdwight's Avatar
No not the buckets
I don't see any way possible to get the actual shifter into the cradle with the buckets already installed unless you cut the bearing bosses.....of course than it would be worthless and ruined.
I am talking about the actual installation of the shifter without the buckets into the plastic original cradle...I had to really lean on mine to get it in....was actually worried I might break or destroy the cradle. My buckets were way undersized so I never completed the installation..Ben has me a new unit on the way...A very professional Guy....Thanks Ben
Dwight
Old 06-10-2015, 12:38 PM   #104
Ben-Auto-Design
Ben006's Avatar
Ok I see now !
well If I remember well it takes some finesse to get it in, but it should go in.
If you want you can remove the first bearing, it might help a little
I received your shifter ! and fixed it
first, don't use grease, it's already lubricated were it needs it!
then I put the buckets in my drill, and ground them with 150grit sand paper, then 500 and 1200.
I almost lost a finger, but now the bearings fit inside
proof (I trid to polish the outside ... didn't work ...) :
Ben
Old 06-10-2015, 03:22 PM   #105
Pdwight's Avatar
Originally Posted by Ben006 View Post
Ok I see now !
Ben
Good to know about the grease, the only instructions I had said to grease the buckets and bearings.
Old 06-10-2015, 04:28 PM   #106
Carlisabadman986's Avatar
I greased the hell out of everything out of instinct. I figured it couldn't hurt.
01 Base Arctic Silver, Top Speed Muffler and Cat Delete pipes, Ben006 Short shifter
Carlisabadman986 is offline   Reply With Quote
Old 06-10-2015, 05:11 PM   #107
Ben-Auto-Design
Ben006's Avatar
I won't hurt at first, but then the grease will keep the dust and look dirty :/
Old 06-10-2015, 05:21 PM   #108
It's hiding under the shift boot. Will it really collect much dust? How is it going to get under there? Osmosis?
Old 06-10-2015, 05:31 PM   #109
Ben-Auto-Design
Ben006's Avatar
from the ventilation. It's hiding, but still. mine was dirty when I took it out !
Old 06-13-2015, 09:38 PM   #110
Pdwight's Avatar
Got mine installed today
I could never believe how much better the shift felt after installation . My replacement shifter fit like a glove and is so much more definite now.
I do have one question while I was quite careful with the cable placement and getting it back where is is supposed to be, second gear feels like it could be a bit further or it should move slightly more to engage better ??
It does not slip or try to slip out of gear....just feels like it not quite there....anyone else have this same situation ?
Dwight
Old 06-14-2015, 12:47 AM   #111
Dwight
Planning to do mine later today(sunday), any tips besides the instructions from B&M?
2003 Boxster S
ohhh my is offline   Reply With Quote
Old 06-14-2015, 04:48 AM   #112
Pdwight's Avatar
my biggest help was to take good pictured with my phone for reference, also I removed the cradle or shifter assembly completely( so I could move it tot he bench...be careful removing the old bushings with a utility knife
Old 06-14-2015, 08:59 AM   #113
Ben-Auto-Design
Ben006's Avatar
Dwight
I'm glad you like it !
I put the cables in the exact same place where they were, and I don't feel that. did you remove the green piece in the bottom of the assembly ? it can interfere with the cables.
maybe try to move the cable a little be more inside the threaded receiver (I don't know how to call it ?).
The most "difficult" part for me was to break to old bushings out, I was a little afraid, but after that, should be easy
Ben
Old 06-14-2015, 01:14 PM   #114
Pdwight's Avatar
I did not remove the green piece....drove it quite a bit today and all gears are engaging well and staying where they should....if it's working leave it alone
Old 06-21-2015, 11:13 AM   #115
Ta DA
Installed mine yesterday.
Very nice - Like it a lot.
Duezzer
Duezzer is offline   Reply With Quote
Old 06-21-2015, 11:32 AM   #116
Ben-Auto-Design
Ben006's Avatar
I'm glad you enjoy it
Ben.
Old 06-21-2015, 12:44 PM   #117
Mine installed last weekend and love it as well. There's still some play in mine, but I think that's from the left plastic thing that's left from the original shifter for the side by side play. Any way to tighten this up?
2003 Boxster S
Old 06-21-2015, 01:11 PM   #118
Ben-Auto-Design
Ben006's Avatar
Yes there will always be some play in the rest on the assembly/cables/gearbox.
I've been told that there is a screw you can tighten in the gearbox but I don't know exactly !
Old 06-21-2015, 04:41 PM   #119
Pdwright,
You will need to remove the green peice. The cable ends will rub. You can also pur washers under the shifter console about 1/8 inch before you run out of stud to bolt it down.
Old 06-21-2015, 06:34 PM   #120
DMage's Avatar
Is there another run of these coming up or do you have any extra in stock now? Interested in picking up one of these. Have some slop in my shifter now and figure when I take the console apart to replace the connectors that probably have play in them would like to just get it all done and install the short shifter too.
DMage is offline   Reply With Quote
