Old 05-18-2015, 05:11 PM   #81
Ben-Auto-Design
Ben006's Avatar
Hi !
Everything should be ready to ship by the end of next week !
I'll PM you !
I still have some left.
Ben
Ben006 is offline   Reply With Quote
Old 05-28-2015, 12:23 PM   #82
Ben-Auto-Design
Ben006's Avatar
Hi !
well, I was a little optimistic ...
Everything is at the machine shop, but I had a problem with some parts, which means that now I have twice the parts to modify to accomodate de ball bearings ... but don't worry, it won't change anything for you
Ben
Old 05-29-2015, 09:40 PM   #83
78F350's Avatar
Originally Posted by Ben006 View Post
Hi !
...I still have some left.
Ben
If you still have some left, I'm in. Sending you a pm.
Old 06-03-2015, 11:24 AM   #84
Ben-Auto-Design
Ben006's Avatar
Hi !
I just got the parts back from the machine shop !
They are perfectly machined !
I'm sorry for the longer wait than expected, but I had some problem with them... I had to machine twice as much parts to fit the BB this time !
that's the other part that I had to modify
Ben
Old 06-03-2015, 03:30 PM   #85
Looking forward to these shipping. Any ESD?
2003 Boxster S
ohhh my is offline   Reply With Quote
Old 06-04-2015, 04:56 AM   #86
Ben-Auto-Design
Ben006's Avatar
Before the end of the week
Old 06-05-2015, 12:28 PM   #87
winter.k's Avatar
Nice work Ben. I'd interested in the next round of shifters. Keep me posted. I have some shifter cores.
Kevin
winter.k is offline   Reply With Quote
Old 06-05-2015, 12:32 PM   #88
Ben-Auto-Design
Ben006's Avatar
Yep you'll have to wait for the next round :/
And if anyone else want some for the next round, just tell me
But it won't be until July !
Old 06-07-2015, 03:53 PM   #89
Ben-Auto-Design
Ben006's Avatar
Hi !
I would like to thank everyone for your trust !
This round of shifter went great, despite the problems I had to face
If you want one now ... just tell me, and as always, when we are enough, we can start
Ben.
Old 06-07-2015, 07:39 PM   #90
Do you have tracking information yet? Excited to get this in and installed!
2003 Boxster S
Old 06-07-2015, 07:45 PM   #91
Ben-Auto-Design
Ben006's Avatar
I thought I already gave you your tracking number?
I'll PM it to you right now
Old 06-07-2015, 08:29 PM   #92
Pdwight's Avatar
Putting the new shifter in place
Who else had problems getting the long shaft in and the side bushing at the same time....or did I miss something.....it was very very tight
Old 06-08-2015, 04:04 AM   #93
PD,
Mine was tight also. Too igh to be smooth.
Old 06-08-2015, 06:25 AM   #94
Ben-Auto-Design
Ben006's Avatar
Was it a drag or the bearings didn't fit at all in the buckets ?
Everyone that was in the first round of shifters, if the bearings don't seem to fit, don't force them inside ! Tell me, I'll fix it (I think I know why but I'm waiting to get Dwight's shifter back).
Those in thz second round, don't worry, they fit (when you'll open the package you'll see them already assembled )
Ben.
Old 06-08-2015, 11:49 AM   #95
put me in for the next round as well.
bokster is offline   Reply With Quote
Old 06-09-2015, 12:48 PM   #96
Ben-Auto-Design
Ben006's Avatar
Ok, every shifter has been sent, you'll get the tracking number right now.
PDwight, I sent your replacement too
The new round of shifter won't have the same problem.
And if you want one, Pm me
Ben
Old 06-09-2015, 01:35 PM   #97
Ben
I'm in CA, got mined today. That was fast, can't wait to get a chance to install it this weekend.
2003 Boxster S
Old 06-09-2015, 01:43 PM   #98
Ben-Auto-Design
Ben006's Avatar
I hope you'll enjoy it
Old 06-09-2015, 03:37 PM   #99
Pdwight's Avatar
Thanks so much
My original question was not about the shifter ends fitting into the buckets, but getting the new shifter into the plastic OEM assembly after removing the original. You insert the long end in first and the the side pin into the bushing....it is very very tight....or an I missing something ??
Old 06-09-2015, 03:50 PM   #100
Ben-Auto-Design
Ben006's Avatar
Oh, I have to remember !
The easiest way is to do it with the whole assembly out of the car.
The way I did, is that I held the shifter in place, with the side pin in the lever, and slid the two buckets through the assembly and over the bearings, then put the clips.
Then finish by tightening the set screw gently (there is no need to use a lot of force here !), and tighten the locking nuts.
The buckets should be tight inside the assembly so there is no play. If they are too tight, a little bit of 400 grit sand paper should clear it
It should work by doing so.
