12-10-2014, 12:58 PM
#21
Ben-Auto-Design
I have received the shifters !
Tomorrow I will get them modified, I just don't know how long it will take !
I haven't the bearings yet but they should arrive soon enough.
then I will ship them to you as soon as possible
Thank you
Ben
12-11-2014, 07:57 AM
#22
Ben-Auto-Design
The shafts are at the machine shop, I hope to have them back on monday.
But the ball bearings aren't here yet :/
lets cross our fingers !
12-16-2014, 10:28 AM
#23
Ben-Auto-Design
Hi everyone
I contacted the seller for the bearings, they will not be there before christmas ...
I'm sorry, I didn't choose the better time for a groupbuy ... but don't worry, everything will be great after christmas
Ben
01-02-2015, 09:35 AM
#24
Ben-Auto-Design
Happy new year everyone !
I just got the ball bearings in the mail today  I'm sorry it took so long :/
I will get the modified shaft from the machine shop monday.
then it may not take too long before I can send them !
More news on Monday
01-03-2015, 01:58 AM
#25
More news on Monday
No stress on my part, s *** y weather at the moment so won't be fitting for a while
David
01-03-2015, 08:08 AM
#26
Get-er-done
No problem for the wait
Weather is not good for the Boxster
01-03-2015, 08:51 AM
#27
Reebuck1
Shifter
Great looking forward to it !!
01-03-2015, 09:49 AM
#28
Ben-Auto-Design
Thank you for understanding !
01-06-2015, 01:18 PM
#29
Ben-Auto-Design
Ok I finally got the rods and bearings back
the machine job did a pretty good job !
but they charge me more than twice what they told me ...
final price will be 115$ with shipping for USA
and 145$ with shipping for Canada.
I will send you a pm
thank you !
Ben
01-06-2015, 02:47 PM
#30
Ben-Auto-Design
01-08-2015, 05:11 PM
#31
Ben-Auto-Design
The first two has been sent !
tomorrow another one will be send
thanks everyone
Ben
01-08-2015, 05:34 PM
#32
Looking forward to getting mine , hope to install after the Ice Age we are having
01-11-2015, 03:32 PM
#33
Ben-Auto-Design
Do you guys have received my PM ?
03-05-2015, 06:19 PM
#34
Any feedback on how these are working?
2003 Boxster S
03-06-2015, 08:21 AM
#35
I took mine out and looked at it at sadly as we got another 6 inches yesterday. I can say it looks and feels like a very quality piece.
I will report in as soon as I do the install!
03-06-2015, 01:58 PM
#36
If anyone is interested in limiting the down-time for the swap, I have an extra stock shift console available for $75. Prep the new shifter in the warmth of your house & do a quick console swap in the freezing cold.
PM me if interested.
98 Arena Red 986
03-06-2015, 03:43 PM
#37
inveniam viam aut faciam
I put mine in and can report that there is zero slop in any direction. Installation was a little tricky because of the tight tolerances with the bearings into the cups, but it went quickly.
Having never used one of these shifters in an unmodified state, I really can't comment if it is an improvement over the shifter with the nylon inserts (or whatever they had originally). For installation instructions I went to the B&M site and downloaded their instructions. This shifter is basically a knock-off of that, but with ball bearings on the longitudinal shafts.
All in all, if you want super short shifter travel and rifle bolt type precision with the accompanying increase in effort, you can't go wrong with this, especially for the price. I would also like to see what the 987/997 shifter is like. I imagine it is not quite as precise, and not quite as short throws, but also less effort.
03-06-2015, 07:47 PM
#38
Ben-Auto-Design
Thanks for the feed back Qmulus
03-07-2015, 02:42 AM
#39
Qmulus,
Test fitting the bearing cups, yes they are tight! How did you get yours on?
Van
03-07-2015, 10:16 AM
#40
Originally Posted by Van914
Qmulus,
Van
Follow the directions for the B&M shifter. Do be careful playing with the bearings before you install it. Mark the shift cable positions with a marker or tape before you remove the cables from the retainers. I did mine in with the transmission in neutral and after putting the cables exactly into the retainers the new shifter was dead on with no adjustment needed. After removing the old shifter parts, you drop the main shifter mechanism into the housing, then slide on the cups. Make sure that you match the notches in the cups with the tabs in the holes in the housing. I put a thin coat of white lithium grease inside the cups to make sliding them on the bearings a bit smoother and need to tap them a bit to get the bearings fully seated to where I could install the C clips.. I also put a bit of grease on the ball that goes into the pivot arm. With the set screws, I put them in backed way out then snugged them up, then backed up just to where there was almost no play in them and locked them with the lock nuts. The inside end of the set screws got a touch of grease on the ends as well.
I can't say how long exactly it took to install it, as I probably spent as much time cleaning as I did working. It is always good to vacuum the carpet where it is hard to get with the console installed, as well as to clean the console and clean and condition the shift knob and boot.
HTH!
