Old 11-08-2014, 10:44 AM   #1
Ben-Auto-Design
Ben006's Avatar
Ball bearing short shifter !
Okay, I need to update that post!
Let's talk about shifters!
What is a short shifter?
A short shifter replaces part of/completely your shifter mechanism:
In order to shorten the distance between gears or "throw", and usually reduce the play for a more precise engagement.
You can see a before and after on the suncoast website: Suncoast Porsche Parts & Accessories Porsche Short Shift Kit
It is not just a shortened lever, and the actual correct name is a Short Throw Shifter.
Externally, when everything is back together, it looks just like before (unless you go cray like me and peel you shift boot and cut your shift knob...
What do I do with those shifters?
First, I don't completely make them from scratch, I use the regular Short shifters that you can buy on eBay. Why ? Because the shifting mechanism isn't subjected to high loads, and the material they use in 10 time stronger than what's needed (what proof ? look at how the cables are attached ). And also, having to completely make them would cost three times the price... not the goal here!
What makes them different then?
When I receive the base shifters, I take them completely apart, check them, grease them with proper high pressure grease. Then I put them back together correctly (they come backward...), while making sure that they function freely and smoothly.
Then, I have the bushing holders (or cup, as I call them) and side cylinders machined to accept 4 ball bearings.
Why 4? Simply because it is the best compromise between machining cost/ball bearing cost/strength.
Do the ball bearings really make a difference?
Yes, I'll talk about it again after, but the ball bearing do make a real difference in feel.
Hard bushings always have some play, or end up with some play once they start to wear. The ball bearings won't wear nearly as fast, and if they do, just replace them with new ones for less than 5$!
On the other hand, good luck finding new bushings! You most likely will need a whole new shifter!
How do they compare?
I had the opportunity to try some other big brand shifters on 996, 986 and a 987.
While they are beautiful part, and definitely worth their price as far as quality goes, the feeling, is still different.
None of them had the same "rifle bolt action" when engaging a gear, and that feeling comes from the ball bearing due to their metal to metal contacts.
What about reliability?
So far, I only had one guy that had a really non-human problem with one of the shifters. I since changed the grease I use to a thicker, stickier one.
I recommend to check them every once in a while, to ensure that everything is still doing it's job properly.
What do they fit on?
Any manual transmission on 9x6 and 9x7 Porsche models.
How hard is it to install?
Pelicanpart has a pretty good write-up on how to install one, and there are a lot more available online!
It is not really hard to install, though there are some tricks, and if you don't feel comfortable, get it installed by someone who already did one, or a shop!
Or me if you want to drive by.
Why do I do this?
It's fun, and very rewarding! I learned a ton of things, and met very nice people doing this!
How to get one?
Check the last pages of this thread, I usually post a message when I'm ready to start.
I'm not a shop, I don't have a stock, I might have one or two laying around from people who canceled theirs, but not often.
You can send me a private message at any time, and I'll put you on my list for the next ones! That means that I will contact you as soon as I'm ready to do more.
You can also PM me if you have any question or need help, even if you got a shifter from somewhere else, no prob
Some pictures:
I think I covered pretty much everything?
Bye!
Ben.
Ben006 is offline   Reply With Quote
Old 11-11-2014, 10:17 AM   #2
Well done on this.
I made my own BB cup style shifter too here in the UK....not one person was interested...so i hope you get better luck!
jimk04 is offline   Reply With Quote
Old 11-11-2014, 11:53 AM   #3
CHRISP357's Avatar
I'm intrigued...
CHRISP357 is offline   Reply With Quote
Old 11-11-2014, 04:54 PM   #4
Bfan's Avatar
I am interested, but naturaly final price matters. I just installed 997 SS í my 65 K mile 01S and it ís like a new car. Newer want it to go back to these sloppy sifts again.....
Bfan
There is no replacement for displacement
Bfan is offline   Reply With Quote
Old 11-14-2014, 08:31 AM   #5
Ben-Auto-Design
Ben006's Avatar
Sorry for the late answer, my parents were visiting me this week so I was busy carrying them around
I'm getting used to the stiffness of the new shifter and I love it !
If I can get 10 persons in, I think I can have them between 100 and 120$ (shipping, lithium grease, and ball bearings included )
as always the more we are, the less we pay
Ben
Old 11-15-2014, 06:01 PM   #6
I'm interested in a set... where are you located in FL?
dijinn is offline   Reply With Quote
Old 11-15-2014, 07:15 PM   #7
Pdwight's Avatar
Yes how much ?
Old 11-16-2014, 07:18 AM   #8
Ben-Auto-Design
Ben006's Avatar
I'm in South Florida, Delray beach
as I said, I plan on 100 to 120$ per shifter with shipping. That's little more than the ebay ones, but a lot less than the "prenium" ones (but with the same specs ... so )
Old 11-16-2014, 08:03 AM   #9
Pdwight's Avatar
Im in
Im in, count me in
Old 11-16-2014, 09:34 AM   #10
Ben-Auto-Design
Ben006's Avatar
cool
I pm you
Dijinn you're in too ? Pm me
Old 11-18-2014, 06:22 PM   #11
Pm' d I'm in.
Scottduvall is offline   Reply With Quote
Old 11-19-2014, 10:52 AM   #12
Ben-Auto-Design
Ben006's Avatar
Nice
Come on, a few more and we are good
Old 11-25-2014, 04:54 PM   #13
Ben-Auto-Design
Ben006's Avatar
Come on we need just one more so everyone can have his shifter
If you don't have one on your car it's time, you won't regret it !
Ben
Old 11-26-2014, 01:51 AM   #14
mavis.d's Avatar
How much do you think it would cost to post to UK. Would right hand drive make a difference?
mavis.d is offline   Reply With Quote
Old 11-26-2014, 04:37 AM   #15
Ben
Count me in
Van914
Old 11-26-2014, 09:24 AM   #16
Ben-Auto-Design
Ben006's Avatar
For France, it will be around 140$, so I guess it will be the same for UK no problem for the RHD !
cool, One more ! let's start so
I pm you all.
edit : I will tell you the final price soon, as I said, between 100 and 120 (I will try to keep it as low as possible )
Ben
Old 11-27-2014, 12:47 PM   #17
mavis.d's Avatar
Smile
OK count me in
Old 11-28-2014, 11:32 AM   #18
Reebuck1
I am very interested. let me know the price..? thanks, reebuck1
Reebuck1 is offline   Reply With Quote
Old 11-28-2014, 02:22 PM   #19
Ben-Auto-Design
Ben006's Avatar
PM sent
Old 12-07-2014, 10:05 AM   #20
Ben-Auto-Design
Ben006's Avatar
Hi !
As I said, with thanksgiving, and now christmas, UPS is slower than usually, so I haven't received the shifters yet :/
But don't worry, all will be good
Ben
