Old 07-06-2015, 12:53 PM   #601
Fintro11's Avatar
Originally Posted by amitmishra4 View Post
+1. I would definitely buy!
I just put led bulbs in mine
Fintro11 is online now   Reply With Quote
Old 07-06-2015, 05:07 PM   #602
Wallace River's Avatar
Mine got here - East coast of Canada!
No problems, all intact, looks awesome. Need to schedule some "me" time to install it :P .
Oh, and what also very neat......didn't get dinged a dime in taxes by the Post Office! Thanks Fred!!
The name's Ian....now a former owner.....sold my 2000 Speed Yellow Base to its new owner in Nova Scotia.
Wallace River is offline   Reply With Quote
Old 07-07-2015, 12:56 PM   #603
ccjazz's Avatar
Got around to installing my Skybreaker the other day. I decided to use the factory phone plug for switched power and it was easy to locate and connect.
This small piece of carpet under the dash slides toward the frunk and exposes the forward console area.
The four wires are Brown- (ground), Yellow- (mutes radio if phone in use), Green- (switched power, 12v when key is turned to accessory), Red- (continuous 12v, not switched).
Spliced into ground (brown) and switched (green) wires and soldered. Apologies for focus and soldering abilities.
The rest was running wires as others have done. Thanks to BruceH for the velcro mounting idea.
I'll post a night pic when I get a chance.
'01 Boxster S (purchased new) triple black, litronics, cruise, heated seats,18's.
ccjazz is offline   Reply With Quote
Old 07-07-2015, 01:01 PM   #604
ccjazz's Avatar
I should have mentioned, if using this plug it was easy to find. Once the small piece of carpet is removed, just reach in and feel around.
Old 07-07-2015, 02:41 PM   #605
Fintro11's Avatar
Put a small cloth over the tip of a flat screw driver you can shove that wire inbetween the roll bar cover
Old 07-07-2015, 02:46 PM   #606
ccjazz's Avatar
Great idea...I'll do that, thanks Martin
Old 07-07-2015, 10:59 PM   #607
A credit card works well, too
Old 07-08-2015, 07:57 AM   #608
Fintro11's Avatar
Lol pshf you gotta do it the millwright way
Old 07-08-2015, 11:42 AM   #609
BruceH's Avatar
I used a plastic trim removal tool from Harbor Freight to tuck the wires. Nicely done ccjazz!
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 07-08-2015, 12:01 PM   #610
Originally Posted by Toppy986 View Post
I pulled off the side panel on the console, drilled a small hole into the cubby, guessing at bottom height. Fed both wires through the hole. Fed the feed wire behind park brake trim into the ashtray area. Cut feed wire at length for ashtray light, and after the white end was connected, coiled up extra wire and stuffed it behind the seat belt post carpet.
I pulled the side panel off (never noticed those came off) and just ran the wire behind the side panel into the bin rather than drill a hole. Seems to work much better than just hanging the wire inside over the top as I had done before ....Thanks
soxfan1966 is offline   Reply With Quote
Old 07-08-2015, 12:09 PM   #611
ccjazz's Avatar
Yeah, I have to re-do those wires, thanks again for the velcro/dash install idea!
Old 07-08-2015, 03:56 PM   #612
amagalla's Avatar
I'll try to get a picture of it later on, but I actually connected mine to the rear parking lights via the bundle of wires that run through the b-pillar trim where the seat belt is mounted. Super easy to get to (tough to find the right wire in the bundle) and short. No need to run wires into the center console.
Tony
Lapis Blue 03 Boxster S
Old 07-08-2015, 04:09 PM   #613
ccjazz's Avatar
Tony
I was thinking about that, or the rear defrost wiring. I wasn't sure how I would find switched power controlled by the ignition switch position so went with the phone plug option. Wanted to avoid drilling holes too.
I'd like to see how you wired that up.
Old 07-08-2015, 06:08 PM   #614
Quite Pleased with myself :)
I got mine installed today, the process went very well. Thanks to all for the tips. I went with the phone plug under the centre console, it was easy to get to and easy to find. Also happy with my colour selection Fred, your product adds a lot and modernizes the look significantly!
Old 07-08-2015, 07:00 PM   #615
BruceH's Avatar
Wow! That looks fantastic
DEPO Tail Lights
Old 07-09-2015, 02:31 AM   #616
Fred,
I know I promised to cool my heels but I'm jealous of all these guys installing their sky breakers. Can you update?
Thanks, Larry
022520 is offline   Reply With Quote
Old 07-09-2015, 05:03 AM   #617
ccjazz's Avatar
That is what I would call a perfect color match! Nice work
Old 07-09-2015, 06:01 AM   #618
That is absolutely sweet looking! First one I have seen in yellow, great match.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 07-09-2015, 01:07 PM   #619
02BoxsterS
Guys. I have a 2002 Boxster S and was looking for a center wind screen.
Where was this purchased? A little information please.
favila69 is offline   Reply With Quote
Old 07-09-2015, 04:32 PM   #620
Rookie
The link is buried back several pages. Possibly a long wait (and Im ahead of you ) as the maker is an enthusiast and gets orders filled as his personal time permits...
Illuminated Wind Deflector Kit for Boxster 986 - English
Welcome to the 986 forum.
02 Seal Grey 5 Speed
TypeA is offline   Reply With Quote
