Old 07-08-2015, 11:01 AM   #610
soxfan1966
Originally Posted by Toppy986 View Post
I pulled off the side panel on the console, drilled a small hole into the cubby, guessing at bottom height. Fed both wires through the hole. Fed the feed wire behind park brake trim into the ashtray area. Cut feed wire at length for ashtray light, and after the white end was connected, coiled up extra wire and stuffed it behind the seat belt post carpet.
I pulled the side panel off (never noticed those came off) and just ran the wire behind the side panel into the bin rather than drill a hole. Seems to work much better than just hanging the wire inside over the top as I had done before ....Thanks
soxfan1966 is offline   Reply With Quote
