Old 04-07-2014, 03:45 PM   #1
1998 convertible top problem
Top does not go up or down. Checked micro switch in latch and it is functioning, brake light on dash is on, indicating micro switch is good. No noise or response when up or down switch is engaged. Checked fuses and all are good. problem started two weeks ago when the top would not engage right away but would later when I went through the process of checking the hand brake, windows and doors closed, hoods latched.
Any Ideas? It seems like I am missing a step
GFOX is offline   Reply With Quote
Old 08-16-2014, 09:11 AM   #2
JB3
Just had the same thing while top was down (would not go up). Dash light is on. I have discovered the passenger side link to top mechanism was disconnected (how long?). Will be digging into the system shortly.
JB3 is offline   Reply With Quote
Old 08-16-2014, 05:05 PM   #3
KevinH1990's Avatar
Here's a good reference on the top: https://sites.google.com/site/mikefocke2/thetop-itsmaintaince%26replacement
There are several topics covered and you can get a good idea of the various components in the system and narrow the number of components you need to check. GFOX sounds like he could have a problem with the motor or the top relay.
