Old 01-27-2017, 06:56 PM   #141
Pdwight's Avatar
OBC still available
I answered your PM
$48 shipped
Thanks for the interest .
Old 01-28-2017, 04:01 AM   #142
2003 Base 5-speed
grc0456's Avatar
Paypal sent. I PM'ed you my address. Thanks!
Old 02-10-2017, 02:01 PM   #143
auBoxster's Avatar
I'm keen on a cable / harness Pdwight - a PM is heading your way :-)
auBoxster is offline   Reply With Quote
Old 02-13-2017, 01:38 AM   #144
4 stalk harness
Hi Pdwight,
New to site and was interested in a wiring harness for a 4 stalk steering column upgrade I want to do on my 2000 Boxster S (RHD). Does your harness do away with putting together the various VW connectors/wires as in 101 thing to do on Porsche Boxster book?
I have the 4 stalk switch with cruise control etc and am looking for simple plug & play type harness which seems to be what you have?
nm24 is offline   Reply With Quote
Old 02-13-2017, 03:34 PM   #145
oldskool73's Avatar
Yes, these are basically premade versions of the harness described in the 101 project book.
Also, for the guys in the UK/AU above... not taking away from what Pdwight is doing as he's certainly making a great product and has pages of great reviews here to attest to that... but there's also an EBay seller in the UK who makes the same thing (and a cruise control version also). With the current exchange rates they work out to be about half the price.
oldskool73 is offline   Reply With Quote
Old 06-17-2017, 06:52 PM   #146
lkchris's Avatar
Installed Dwight's nice cable about a year ago and bought a Durametric and got OBC activated. However, nothing on the dash. Retry with Durametric said already activated.
So this week I installed the 3-blink turn signal upgrade and decided to check my obc wiring at the same time. For a while now I've owned a complete 996 dash wiring harness (must weigh 100 lb) and was able to track down the obc wiring in that to enable me to verify the pin connections, in case I'd miswired the dash connector--I hadn't.
Anyway, after getting everything back together obc now works and I'm really happy.
Moral to the story? Guess it's possible to not get that gray connector (mine's 2001) correctly reattached to the cluster ... or perhaps I didn't get the black connector block back into the gray holder correctly. My car is manual trans and there's only one other wire in the gray connector--don't know what it is but saw no other problem during the year not having gray connector correct.
3-blink works, too, but it was a big hassle ...obc activation was a piece of cake in comparison... just don't be confused by suggestions you need to remove steering wheel. Obc lever is separately removable from the rest, so you can just bolt it on to your existing configuration.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 06-17-2017, 08:16 PM   #147
Pdwight's Avatar
I had a similar problem originally
Check all your connectors on the back of your instrument cluster...I cant remember which one it was but one was not plugged all the way in.....it looked like it was....but was not.
Also be carefull with the instrument cluster wiring connectors....mine started disintegrating as I was removing them and reinstalling them
Old 06-19-2017, 04:05 AM   #148
Luckyed
Luckyed's Avatar
Same here.....very fragile!!
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 06-19-2017, 04:06 AM   #149
Multi-Boxer Driver
Deserion's Avatar
I had the same issue when I did my install. Oops.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 08-10-2017, 09:37 AM   #150
PM sent, thanks
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
WhiteyII is offline   Reply With Quote
Old 08-16-2017, 06:25 PM   #151
Pdwight's Avatar
A new Harness is
On it's way back to you
Dwight
Old 08-19-2017, 12:37 PM   #152
Dwight very nice harness, very professional work...... Thank you
Dave
1998 Boxster
Old 11-18-2017, 02:10 AM   #153
Another one
Hi Dwight,
I sent you an email I would like to purchase your wiring harnesses for the 4 stalk too. I have a MY03 Base as well.
Thank you,
David
Tigger19 is offline   Reply With Quote
Old 11-19-2017, 06:48 PM   #154
Pdwight's Avatar
PM Sent
Check your message box
Old 05-05-2020, 12:24 PM   #155
Dwight,
I sent you a PM asking if you're still making the harnesses.
Thanx,
Harry
1970 911T Hot Rod
2003 Boxster S
2018 Macan S
2021 718 Spyder
Balloonmeister is offline   Reply With Quote
