		|  05-10-2015, 05:43 PM | #81 |
	| Registered User
				Join Date: Jun 2013 Location: Nanaimo, Vancouver Island, British Columbia, Canada
					Originally Posted by Pdwight  Did you get your harness yet ? |
Nope, got the Switch though    got bored and half installed it    pretty easy to do once the harness comes I'll take some pictures and do a little install guide. Pretty excited    |
		|  05-10-2015, 05:47 PM | #82 |
	| Registered User
		|  05-10-2015, 06:54 PM | #83 |
	| Registered User
			with the harness it will be a cakewalk, please let me know when it comes in
 Dwight
		|  05-13-2015, 08:35 AM | #84 |
	| Registered User
			Finally got everything installed, 4th stalk in place and buttoned up.  Connected the Durametric, activated the OBC.........FAIL.  :troll:
 Could not get the correct number of bytes back from the OBC plus I received a fault code of 5555.
 I am confused.  Do I need to go to the dealer and have the factory code turned on with the PIWIS(?).
				__________________2004 Boxster S
		|  05-13-2015, 08:53 AM | #85 |
	| Registered User
				Perhaps not a fail
			I had the same situation when I did my install, I drove to another members home and he had a PIWIS (spelling?)and it still did no good. What it turned out to be was a connection. Double check the connector you inserted the pins into at the back of the instrument panel, make double sure it is completely plugged in all the way...easy to have it askew .
 Also be sure none of your pins pushed out of the connector....if you saw the triangles they should stay in place.
 Next thing to try is the actual 4 stalk, I had a cold solder joint in the OBC lever on the ground.....easy to "Ohm" this lever out.
 Let me know if I can ever help
 Dwight
		|  05-14-2015, 02:51 PM | #86 |
	| Registered User
			Dwight,Took it apart and put it back together.....It now works.
 Go figure.
 Thanks for all your help & you too Bruce.  The harness worked great.
 One word of advice to all who want to do this hack.  Put the top down first.  Life will be much easier.   Ask me how I know.
 Don
		|  05-14-2015, 03:00 PM | #87 |
	| Registered User
			Glad to see you got it working Don! Happy to help
				________________________________________________________________
 2001 Boxster S Lapis Blue
 iPad Mini Dash Install
 DEPO Tail Lights
		|  05-14-2015, 06:05 PM | #88 |
	| Registered User
				Happy Ending
			Without going to a parlor
Glad you got it worked out
Dwight
		|  05-20-2015, 03:23 PM | #89 |
	| Registered User
			Where is the connector where the pins go in?
		|  05-20-2015, 07:14 PM | #90 |
	| Registered User
			The connector on the back of the instrument cluster
		|  05-20-2015, 08:04 PM | #91 |
	| Registered User
					Originally Posted by Pdwight  The connector on the back of the instrument cluster |
lol I never realized you had to take the instrument cluster out, after a bit of googling I figured out ... with googling included it was a 15 min job    thanks Dwight!
		|  05-20-2015, 08:06 PM | #92 |
	| Registered User
		|  05-20-2015, 08:07 PM | #93 |
	| Registered User
		|  05-21-2015, 11:06 AM | #94 |
	| Registered User
			This is the first I have seen of this.  Cool that i can activate the OBC on my 2001 S.  I have a 3 stalk so is there another place where I an look at step by step procedure for the upgrade?
 Also, do I need to buy a 4 stalk?
		|  05-21-2015, 11:17 AM | #95 |
	| Registered User
					Originally Posted by jpc763  This is the first I have seen of this.  Cool that i can activate the OBC on my 2001 S.  I have a 3 stalk so is there another place where I an look at step by step procedure for the upgrade?
Generally, it is tough to buy just the stalk. I bought a 4 stalk and removed the OBC stalk from it and installed the stalk on my OEM 3 stalk. Then run Dwight's harness from there to the gauge cluster. Pelican has a good DIY guide with pictures. You will then have to have your computer activated. I went to my local indie mechanic who charged me $50. The stalk ran $129 from Oklahoma Foreign on eBay.
 DEPO Tail Lights
		|  06-07-2015, 10:58 AM | #96 |
	| Registered User
				__________________Kent Christensen
 Albuquerque
 2001 Boxster
 2007 GL320 CDI, 2010 CL550
 2 BMW motorcycles
		|  06-09-2015, 06:16 AM | #97 |
	| Registered User
			Here is a cheap 4 stalk with faded lettering I saw on eBay today. No relation to the seller.99 04 Porsche 911 996 Boxster Turn Signal Wiper Column Switches Faded Letters | eBay
 DEPO Tail Lights
		|  06-09-2015, 10:57 AM | #98 |
	| Registered User
			Faded letters are meaningless as it's just a little cap that pops off and is easily replaced
 Albuquerque
 2001 Boxster
 2 BMW motorcycles
		|  06-09-2015, 02:40 PM | #99 |
	| Registered User
				Truth
			And this is a deal
		|  07-01-2015, 07:29 PM | #100 |
	| Registered User
				Cable
			Are you still selling cables? I need the OBC cable on a 4 stack for a 2000 Boxster s
				__________________SciGuy
 2000 Boxster S (13K miles)
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 08:51 PM.
