05-10-2015, 06:43 PM
#81
Originally Posted by Pdwight
Did you get your harness yet ?
Nope, got the Switch though  got bored and half installed it  pretty easy to do once the harness comes I'll take some pictures and do a little install guide. Pretty excited
05-10-2015, 06:47 PM
#82
05-10-2015, 07:54 PM
#83
with the harness it will be a cakewalk, please let me know when it comes in
Dwight
05-13-2015, 09:35 AM
#84
Finally got everything installed, 4th stalk in place and buttoned up. Connected the Durametric, activated the OBC.........FAIL. :troll:
Could not get the correct number of bytes back from the OBC plus I received a fault code of 5555.
I am confused. Do I need to go to the dealer and have the factory code turned on with the PIWIS(?).
2004 Boxster S
05-13-2015, 09:53 AM
#85
Perhaps not a fail
I had the same situation when I did my install, I drove to another members home and he had a PIWIS (spelling?)and it still did no good. What it turned out to be was a connection. Double check the connector you inserted the pins into at the back of the instrument panel, make double sure it is completely plugged in all the way...easy to have it askew .
Also be sure none of your pins pushed out of the connector....if you saw the triangles they should stay in place.
Next thing to try is the actual 4 stalk, I had a cold solder joint in the OBC lever on the ground.....easy to "Ohm" this lever out.
Let me know if I can ever help
Dwight
05-14-2015, 03:51 PM
#86
Dwight,
Took it apart and put it back together.....It now works.
Go figure.
Thanks for all your help & you too Bruce. The harness worked great.
One word of advice to all who want to do this hack. Put the top down first. Life will be much easier. Ask me how I know.
Don
2004 Boxster S
05-14-2015, 04:00 PM
#87
Glad to see you got it working Don! Happy to help
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
05-14-2015, 07:05 PM
#88
Happy Ending
Without going to a parlor
Glad you got it worked out
Dwight
05-20-2015, 04:23 PM
#89
Where is the connector where the pins go in?
05-20-2015, 08:14 PM
#90
The connector on the back of the instrument cluster
05-20-2015, 09:04 PM
#91
lol I never realized you had to take the instrument cluster out, after a bit of googling I figured out ... with googling included it was a 15 min job  thanks Dwight!
05-20-2015, 09:06 PM
#92
05-20-2015, 09:07 PM
#93
05-21-2015, 12:06 PM
#94
This is the first I have seen of this. Cool that i can activate the OBC on my 2001 S. I have a 3 stalk so is there another place where I an look at step by step procedure for the upgrade?
Also, do I need to buy a 4 stalk?
05-21-2015, 12:17 PM
#95
Generally, it is tough to buy just the stalk. I bought a 4 stalk and removed the OBC stalk from it and installed the stalk on my OEM 3 stalk. Then run Dwight's harness from there to the gauge cluster. Pelican has a good DIY guide with pictures. You will then have to have your computer activated. I went to my local indie mechanic who charged me $50. The stalk ran $129 from Oklahoma Foreign on eBay.
DEPO Tail Lights
06-07-2015, 11:58 AM
#96
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
06-09-2015, 07:16 AM
#97
Here is a cheap 4 stalk with faded lettering I saw on eBay today. No relation to the seller.
99 04 Porsche 911 996 Boxster Turn Signal Wiper Column Switches Faded Letters | eBay
DEPO Tail Lights
06-09-2015, 11:57 AM
#98
Faded letters are meaningless as it's just a little cap that pops off and is easily replaced
Kent Christensen
Albuquerque
2001 Boxster
2 BMW motorcycles
06-09-2015, 03:40 PM
#99
Truth
And this is a deal
07-01-2015, 08:29 PM
#100
Cable
Are you still selling cables? I need the OBC cable on a 4 stack for a 2000 Boxster s
SciGuy
2000 Boxster S (13K miles)
