Old 07-21-2014, 10:37 AM   #41
lkchris's Avatar
Quality Porsche Parts on eBay may have even better selection than Oklahoma Foreign
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 09-26-2014, 06:23 AM   #42
Looks like an amazing job with the cables. I would love to do this to my Boxster. Bump for good DIY.
Update: ordered a set and received them in the mail. Just as I thought, top notch work, thanks.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 10-22-2014, 12:27 PM   #43
Sent a PM. Tell me how to pay you for this as I want a set of cables for the 4 stalk OBC. Thanks!
robbiex1 is offline   Reply With Quote
Old 10-26-2014, 04:29 PM   #44
jim_hoyland's Avatar
If I have the outside temp showing does that mean the OBC is on ?
jim_hoyland is offline   Reply With Quote
Old 10-26-2014, 05:11 PM   #45
Pdwight's Avatar
Yes, it should be on if you are seeing the outside temp
Old 11-03-2014, 03:13 PM   #46
Received the switch with the wires; very well done ! I have a question regarding the placement of the switch. Previously I've read that some switches are left or right only; that is that fit on one side of the air/heat console but not the other. All my slots on the right (passenger side ) are full; this leaves me with only the driver side. Will the switch work on the left (driver side ) ?
Second question: is a second switch required to make the "speed gong" operational ?
Jim
Old 11-04-2014, 04:08 AM   #47
Pdwight's Avatar
Yes
Install in any vacant switch opening.
Old 11-15-2014, 01:53 PM   #48
Is a separate switch required to set the speed gong ? How is the speed set ?
Old 11-15-2014, 05:52 PM   #49
Pdwight's Avatar
Im not sure if you can set the speed gong with a simple dash switch. I could provide a 4 stalk cable and you could add two switches I suppose to get the entire abilities....but I have no experience with that
Old 11-21-2014, 04:50 AM   #50
We installed the OBC switch and have found the wiring job excellent; the switch now allows the function to cycle through. I have a couple of questions:
1. The switch has two buttons but only one seems to cause the OBC to cycle. Pressing the other side doesn't appear to have any effect ? Is this normal ?
2. Is there anyone out there who did the two (2) switch installation ? Would like clarification whether this allows setting the speed gong function
I would recommend Dwights harness to anyone wishing to use the OMC, it's a nice upgrade.
Old 11-21-2014, 07:54 AM   #51
Pdwight's Avatar
Thanks Jim, projects from my very own "Skunk Wurx" Shop...made by hand
Old 11-21-2014, 08:56 AM   #52
eicheldp's Avatar
Hi PD,
I still have your switch harness you sent me, but I ended up buying a 4 stalk switch. Go figure. What modifications would need to be done to make the conversion from the switch harness to the 4 stalk harness.
Is the length the same?
Do I need to add 2 more wires with the connectors?
2004 Boxster S
eicheldp is offline   Reply With Quote
Old 11-22-2014, 04:59 AM   #53
eicheldp's Avatar
Originally Posted by eicheldp View Post
Hi PD,
PD,
Answered my own question. When I posted previously, I was at lunch on the work computer that doesn't allow photos. Sent you a PM.
2004 Boxster S
Old 02-21-2015, 02:08 PM   #54
Need For Speed
KRAM36's Avatar
4 Stalk is in and functioning perfectly. Thanks for the killer wire harness Pdwight!
2003 Boxster S
Old 02-21-2015, 03:34 PM   #55
eicheldp's Avatar
[QUOTE=KRAM36;437246]4 Stalk is in and functioning perfectly. Thanks for the killer wire harness Pdwight!
Hi Kram,
I'm in the process of doing the same on mine using Pdwight's harness. My question, where did you find the shroud where the stalks protrude?
Or did you dremel the lower hole?
2004 Boxster S
Old 02-21-2015, 04:11 PM   #56
Need For Speed
KRAM36's Avatar
I bought the whole unit off eBay for $199.99 shipped.
There is another one for sale by the same person I bought mine from.
Porsche 996 99 05 986 Boxster 97 04 4 Stalk Combination Turn Signal Unit | eBay
2003 Boxster S
Old 02-21-2015, 04:17 PM   #57
BruceH's Avatar
[QUOTE=eicheldp;437258]
Hi Kram,
The rubber shroud has pre marked indentations on the back side. All you need is a utility or exacto knife to cut it out.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 02-21-2015, 04:17 PM   #58
Pdwight's Avatar
Suncoast
THese folks have some of the hard to find stuff...even the caps for the different "handles"
Old 02-21-2015, 04:19 PM   #59
Fintro11's Avatar
I need to do this
Old 02-21-2015, 04:23 PM   #60
Pdwight's Avatar
Let me know
I will fix you up with a harness
