12-30-2013, 06:42 PM
#121
Originally Posted by BruceH
I saw that. The Pioneer I have is a single din. App Radio is a great start, but doesn't compare to actually having an ipad installed. The install of the mini really is not that difficult. Highly recommended!
I will definitely look into a straight mini install as you have done. Do you find the SIM card model useful or do you hotspot with your mobile phone? I guess it is tricky to access once imbedded.....but does look clean. Can you attache gps modules before it goes in? The app radio face is a bit messy for my taste.
The current app radios are double din are touted to work all applications just the mini would.....never tried one though....using a mini right now!
986 00S
12-30-2013, 07:15 PM
#122
Originally Posted by jaykay
I will definitely look into a straight mini install as you have done. Do you find the SIM card model useful? I guess it is tricky to access once imbedded.....but does look clean. Can you attache gps modules before it goes in? The app radio face is a bit messy for my taste.
Only the mini with 4g capabilities will have a gps in it. I don't know of a way to add a GPS otherwise. The 'sum card model' is the 4g one, and in my view, it's absolutely necessary... Unless you are willing to tether from an iphone every time.
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
12-31-2013, 08:00 AM
#123
You definitely want to get the mini with the GPS/LTE chip installed. If you buy used, it won't be that much more, if you buy new, it is an extra $128 I believe. You can buy an external GPS but cost wise, it is about the same as getting it built in and then you would have another device that needs to be charged.
Amazon.com: Dual Electronics XGPS150A Universal Bluetooth GPS Receiver for Portable Devices: Electronics
The other advantage of the mini over APP Radio is screen size and of course customization. I have my home screen set to be fairly clean with only the apps that I use most in the tray. I swipe to get to the other apps that aren't as frequently used. You also aren't limited to the apps that Pioneer supports. The mini is not hard to access, the wings on the horseshoe pop out without much effort. I have the mini set to sync via wifi which it does from the garage. All in all, it is one of those great bang for the buck mods. I bought a used horseshoe so I can go back to stock anytime.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
04-19-2014, 09:11 AM
#124
I finally got around to getting my GoPoint BT1. Here are a couple of screenshots from Dash Command:
For those who are interested in this mod and don't want to modify their horseshoe, here is one on eBay that is reasonably priced:
2000 00 Porsche Boxster 986 Black Upper Center Console Trim 98655213106 51 067 | eBay
I bought a used one and modified it and still have my original if I were to ever want to go back.
DEPO Tail Lights
04-28-2014, 05:47 PM
#125
I am doing something similar with the Parrot Asteroid Smart. it runs Android and there are a few OBDII apps on the Asteroid market, more if you want to side load from the Android market.
I got a very cheap Bluetooth dongle connected to the Parrot no problem
I'm using torque Pro at the moment.
04-28-2014, 05:55 PM
#126
That looks great!
DEPO Tail Lights
04-29-2014, 01:51 PM
#127
Thanks for your thoughts! Did anyone devise a removal system so that you can take the tablet with you? How are all properly securing the tablet in the dash?
From what I can see quickly: It looks like one has to hollow out the upper din rack leading edges to match the iPads rear housing and then make certain adjustments to the horse shoe for clearance; pad up the inside of the horseshoe; snap on horseshoe side covers to retain the iPad. Looks tricky to shape just right; is just the horseshoe that gets dremeled?
-What are the adjustments to the horseshoe and how did were they made to look this good!
- Are you powering the iPad directly from the Becker?
-What audio out cable is needed for the Becker?
-Is there any need to retain a USB input....What does the power cable configuration look like??
-What is the best horseshoe model to use??
986 00S
04-29-2014, 03:46 PM
#128
WALDMEISTER
My idea will be as follows:
I have a 996 cup holder installed, which "swings" open, so the iPad mini could use that to slide in and out with one push.
Only drawback: The bottom part of the "horseshoe"-frame has to be removed or modified with a "flip up/down" mechanism to maintain kinda oem-looks.
Next problem to solve: A small, lightweight, reliable bluetooth "brand" car amplifier, with usb port, so i don't need a car Audio/Radio. Or maybe go for active bluetooth speakers...
Ideas are there, but is the technology ready? We will see
04-29-2014, 09:35 PM
#129
Thanks for your thoughts! Did anyone devise a removal system so that you can take the tablet with you? It takes all of 30 seconds to pop off the wings and remove the ipad.
Take a look at this thread:
iPad Mini in-dash install [996 MkII] - 6speedonline.com Forums
Lots of great information in there.
From what I can see quickly: It looks like one has to hollow out the upper din rack leading edges to match the iPads rear housing and then make certain adjustments to the horse shoe for clearance; pad up the inside of the horseshoe; (No padding)snap on horseshoe side covers to retain the iPad. Looks tricky to shape just right; is just the horseshoe that gets dremeled? The wings also get Dremeled.
-What are the adjustments to the horseshoe and how did were they made to look this good! Take your time with the dremel!
- Are you powering the iPad directly from the Becker? Yes, but I have now swapped out the Becker for a Pioneer HU with dual USB outputs.
-What audio out cable is needed for the Becker? I used this - iP-BKR2 iPod Adapter for Becker and other Radios with "AUX" Menu Setting :: iPod Adapters & Interfaces and a 30 pin to lightning adapter.
-What is the best horseshoe model to use?? What you already have, or buy a used one(I did) so that you can always go back or if you want or practice your dremel skills on the used one.
Read through this thread and the other thread on sixspeedonline forum. All of the information is there and quite easy. Just take your time. You can mark your line on where you want to remove material with tape, and then just start cutting.
DEPO Tail Lights
05-01-2014, 08:44 AM
#130
Nice..thanks guys
Now what I am really after is oil pressure displayed on start up....is the blue tooth com up to that?( oil temp and alt as well)
Digital gauges that pretend to real ones I see all seem a bit cheesy. It would be great to to get simple graphics display in place B-767 style, racepak etc. style
986 00S
05-01-2014, 11:59 AM
#131
There are a lot of gauge choices (and you can make your own style) with both Torque (android) and dash command (android, ios).
my '99 non-s doesnt support oil pressure or temp, but alt voltage and actual water temperature, engine vacuum, MAF air rate, timing, O2 sensor voltages etc are some of the good ones.
09-04-2014, 09:14 PM
#132
Did any of you have difficulty moving the radio down to the storage bin area? It seems like my cdr220 won't fit more than 3/4 of the way in the slot. Doesn't seem like anything blocking it and I don't want to push too hard.
2001 Boxster S 6speed- weekend warrior
2015 Explorer Sport- New DD
2011 Taurus SHO- Sold
2010 CBR1000RR- Sold
09-04-2014, 10:20 PM
#133
I had that issue. There was a little tab sticking out in the lower shelf and I ended up filing it down to get the radio to slip in smoothly.
09-05-2014, 12:13 AM
#134
How do you keep it on ? , how do you get it to stay on and not go to sleep when driving ?
Im sorry if these are dumb questions but I do not know much about Ipads
09-05-2014, 12:35 AM
#135
Ipad mini in-dash installation
In setting-> general-> auto lock
Make the timeout never. You'll need to enable the accessibility switch control to lock it after the cR turns off though.
If the ipad is jail broken then you can download activator and have the ipad auto lock when the tablet stops charging (car turns off) and never lock while it's charging (car is on)
09-05-2014, 07:35 AM
#136
Go to settings > general > accessibility > AssistiveTouch and select on. This gives you a little round button in a square, you can see it on the bottom right corner of my screen. Touching it gives you several choices. To lock the screen, touch the button, select device and then lock screen, viola! You can also rotate the screen, adjust volume and other items. You can move it any where you want on the screen. Love the new wallpaper
There are no dumb questions  Like Shehadehd said, go to Settings>General>Autolock and select "Never" and the iPad will stay on.
DEPO Tail Lights
09-05-2014, 10:10 AM
#137
Bruce when you had the original setup with the CDR220 and the iPod adapter did your mini charge? Mine will detect and play audio, but it says "not charging" next to the battery meter.
09-05-2014, 10:13 AM
#138
Yes, it charged. It also displayed not charging but it did in fact charge. It was nice because the CDR-220 always provided power to the iPad even with the key out of the ignition. My after market Pioneer only charges when the the ignition is on, so if I don't drive the car for several days, sometimes the iPad battery level is low.
DEPO Tail Lights
09-05-2014, 10:14 AM
#139
jail broken
enlighten me ??
I found it, thanks
I would really like to do this instead of a double DIN install
09-05-2014, 10:32 AM
#140
enlighten me ??
I found it, thanks
Lots of great information. I bought a used horseshoe and kept my original in case I want to go back to stock. Also didn't want to practice on my OEM horseshoe  I bought it from Oklahoma Foreign on eBay. Take your time and it is all pretty easy. If you read through the above thread, you won't have a problem
DEPO Tail Lights
