Old 04-24-2013, 05:58 PM   #1
Redmond's Boxster
Air con LCD gone fuzzy and un readable
Hi guys
I was wondering if anyone else had the same problem with there LCD screen on the air
Con unit, if so were can I get a replacement is there one on eBay? It's simply the LCD screen and I can't read the temperature and there's some sort of fuzzy running along the bottom of it
Thanks!
Redmond Boxster is offline   Reply With Quote
Old 04-24-2013, 07:11 PM   #2
thom4782's Avatar
LCD is probably leaking internally. Search the web for Module Master. It sells a replacement LCD that is very easy to install. You might also find AC LCDs on the web from an AUS supplier. Price in US is about $60.
PS: there is a good chance you can find one on EBay too.
Old 04-24-2013, 10:13 PM   #3
Redmond's Boxster
Thanks so much for your response will see how I go!
