Air con LCD gone fuzzy and un readable
Hi guys
I was wondering if anyone else had the same problem with there LCD screen on the air Con unit, if so were can I get a replacement is there one on eBay? It's simply the LCD screen and I can't read the temperature and there's some sort of fuzzy running along the bottom of it Thanks!:cheers: |
LCD is probably leaking internally. Search the web for Module Master. It sells a replacement LCD that is very easy to install. You might also find AC LCDs on the web from an AUS supplier. Price in US is about $60.
PS: there is a good chance you can find one on EBay too. |
Thanks so much for your response will see how I go!
| All times are GMT -8. The time now is 10:53 AM. |
