Old 04-05-2013, 03:41 PM   #1
FYI: headlight connector pinout
When I did my projector install, I wanted to keep it clean, so I pulled the pins out of the connector, removed all of the OEM wiring, and soldered the new projector wiring directly to the pins.
I needed to know which pin was which, but couldn't find a pinout. Here it is for anyone who may need it.
Both the driver and the passenger sides are the same.
Old 04-05-2013, 06:07 PM   #2
1999 base
Meir's Avatar
Great info.
Thanks.
Old 04-09-2013, 01:38 PM   #3
still plays with cars...
BoxsterSteve's Avatar
Thanks particlewave!
This is great information.
With this, I could connect a xenon or bixenon projector conversion on a scorched set of headlights through the factory wiring & connector, correct?
Six speed 2000 Boxster S
