Old 02-22-2013, 04:12 PM   #1
Drivers window goes down a 1/3 when closed...
Hi, new to the forum and my first Porsche Just bought a 2000 Boxter (66,000 miles) yesterday and discovered the drivers side window will go down about a third way down every time I close the door. I was also told it had a "manual" top, just discovered it of course was auto but disabled. The connecting arms are off. Any ideas where I should start. Thanks ~Harold
chwnc is offline   Reply With Quote
Old 05-02-2013, 01:33 PM   #2
Likes her Top OFF
nakedteets's Avatar
Same happens to my drivers Window and my passenger doest stay down when door opened... Started happening when I replaced the tires... This king they checked the batt maybe and it got disconnected?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
nakedteets is offline   Reply With Quote
Old 05-02-2013, 02:27 PM   #3
Sounds top related as my windows go down about that much once I start to lower the top.
Rickinduncan is offline   Reply With Quote
Old 05-02-2013, 11:55 PM   #4
Most likely a bad micro switch in the top or door latches...or several.
