I have this as well, also charges and plays iPhone 5 with the Lightening-to-30 pin adaptor.
Ok now how do we get the cup holders out? I wanna do this mod. I hate CDs.
You pop out the trim piece with a thin flathead or trim remover. Just 4 snap in pins on the corners. Then held in with 4 phillip screws that you can easily locate. Remove those and pull the cupholders out. Tada! :)
Cool, thank you. I'm going to order the part now.
If I have a CDR 220 and don't have the CD changer, will it disable the built in CD player?
rcbox-no. The built in cd will be fine. Its just that the Becker is set up to EITHER accept an aux input, OR be mated to a CD changer with which it has a proprietary protocol for certain functions. In either case, the phone and internal inputs (radio,cd or cassette) are not impacted.
Ok help guys I removed the cup holders to access the stereo but where the hell do I plug this thing in? I can't see the rear of the radio to make the connection. I downloaded the instructions but it shows with the radio out, I don't have keys to pull radio. Any ideas? Help!!! In in here now
Ok I figured it out solo, I'm so proud of my self👍👍👍. I don't have a cd changer so I had to pull out the yellow amp plug and join it with the green and blue and plug it all back together.
It'll be on the left side (when looking at the radio from sitting in the seat). Just feel around and look at the radio diagram in your owners manual. You'll see easily where it'll plug in. Get the tab aligned and oriented, and it'll pop in.
Hey guys, quick question.
So, is it possible to install an iphone 5 adapter to my 1999 porsche boxster radio? and it will charge and play it in auxiliar mode? thanks a lot, hope it is, cause i was about to change a bunch of stuff rearrenge the dashboard and everything. Im looking for the most practical solution.. Cheers |
http://store.apple.com/us/product/MD823ZM/A/lightning-to-30-pin-adapter |
I just ordered the adapter online from Discount Stereo. I think I am going to Best Buy to have them install it. For $49.95 they will install it and also provide the holder for the iPod. Thoughts?
What kind of holder? It is very simple to do. I routed the cable through the cubby for a clean install. $50 isn't bad if you don't have the desire to do it.
Yes, it's a fair price. Post a pic of the holder when it's done.
$50 I think is a sweet price for the job. I say go for it.
I have this and it works great. I also bought a bunch of $5 knock off adapters from eBay. They will work to charge the iPhone 5 but will not transmit audio even though they say they will. So you have to spend $30 for the stupid Apple one. |
| All times are GMT -8. The time now is 06:16 PM. |
