Old 07-13-2012, 10:24 AM   #11
jb92563's Avatar
Originally Posted by Nimbus117 View Post
Easiest way to run the camera cable is under the carpet on the rear shelf and the black foam water channel with the roof in the service position. Take the carpet out in the rear trunk and look at the bulkhead you will see a perfect sized hole to run the cable through. I drilled a hole near the license plate, put the spoiler up, fed a piece of string through the hole I just drilled and hooked it from the spoiler with a piece of wire and pulled up the camera cable. There is a grommet you can use to get the wire into the trunk which is accessed inside the trunk. One thing, the trunk floor does get pretty hot where I fed the cables so put your RCA connector somewhere cool as I had trouble with mine. The positive wire to the reversing light is permanently live which was good (if not a bit confusing).
Mine is the 2003 model with the lousy MOST system, I removed the lot and got a good price on fleabay. Front and rear speakers I connected to the head unit speaker connections and an RCA plugged into the subwoofer output and out into the battery bay just above the pedals. This runs to an Alpine amp where the Porsche amplifier and multi-changer were, this then feeds back the the subs in the doors. I had alternator whine at first but this configuration got rid of it.
Good luck.
That will help a lot routing the camera wire as I had no idea how to get it to the plate area.
Much appreciated....thanks
OK, now I'm going back out to continue the job.
