Old 10-23-2012, 08:22 PM   #161
mcomet's Avatar
I am with Kyle on this one... I have litronic and washers as well. But these led lights really upgrade the look of the car to more modern. Not sure what to do about removal of washers tho I imagine it would be possible. The other question tho is if this is made for non HID setups would the actual connectors or wiring be different?
Otoh I might keep my lamps for a while but I am curious ....
Michael Comet - www.comet-cartoons.com
2014 Guards Red Cayman S - PSE - PASM - 20"CC - INFTMT - CONV - etc..etc...
SOLD - 2003 Speed Yellow Porsche Boxster S - LNE IMS - Klisstle Rollbar Cover
mcomet is offline   Reply With Quote
Old 10-23-2012, 08:28 PM   #162
kyleturner2020's Avatar
I was just wondering about the connectors as well....
2000 Boxster S
2007 H3
kyleturner2020 is offline   Reply With Quote
Old 10-24-2012, 08:53 PM   #163
mcomet's Avatar
I contacted them. The reply I got is that the connectors will be the same. However of course doing HID on these means a separate ballast kit as opposed to our current litronics. Also if you have washers like me that will cp,rout with the light, I am or sure what will need to happen to close up the connector feeding the fluid for that. Maybe crimp somehow?
This might be enough to dissuade me for while. The OEM stock litronics are actually valued more than these.. Something to keep in mind. I am curious to know if I anyone who actually had stock HIDs had done this mod and what their thoughts are...
Old 10-25-2012, 12:41 PM   #164
interesting, thanks. My headlights become hazed every few months so I was looking into this. I wonder how hard it is to just remove the whole washer system?
2000 Boxster S
2007 H3
Old 12-14-2012, 01:18 AM   #165
If you buy a set of the LED HL you can sell me yours.
SF-Rockster is offline   Reply With Quote
Old 12-14-2012, 01:07 PM   #166
There really is no other way than tint spray or replacing the headlights for clear units. The only amber removal you may have read about is taking the inner amber lens out of the clear head lights.
Michiganstar is offline   Reply With Quote
Old 12-14-2012, 07:08 PM   #167
Huh?
Ok, then. Thanks for the tip?
Old 01-01-2013, 06:19 PM   #168
For the low beams, I've had HID's hooked up and have been running them all along.
A week ago, the right HID headlights would not turn on. I've swapped sides/bulbs, hooked up another ballast and tried everything. The right HID headlights will not turn on. If I install halogen H1 bulbs, they both light up without a problem....anyone have a clue?
I have both sides grounded the same way. The right will not light up and will blow the fuse every other time I take the headlights out and try to reinstall them. Weak battery?
geetee is offline   Reply With Quote
Old 01-22-2013, 10:57 PM   #169
Originally Posted by boxster7614 View Post
Thought I would throw my version into this thread.
I really like those. Where are they from?
Old 01-23-2013, 02:52 AM   #170
^ he made them himself.
Old 09-18-2013, 07:30 PM   #171
PCC
Old thread, but I'll give an update on the led headlights.
I was one of the first who bought a black set and I ended up with major dramas.
Fog light burn out, crazed lens and fogging.
Just received the gen 2 set after some 6 months! Look the same as the old set, but quality appears much improved. Jeffrey at xtreme has been very helpfully considering his hands have been tied waiting for the new version to been released.
This set have 27w fogs and I'll install a low beam hid kit to keep the units cool.
Will post a progress update in a few weeks.
Thanks Jeff for your persistence
PCC is offline   Reply With Quote
Old 09-18-2013, 09:21 PM   #172
BruceH's Avatar
Thanks for the update. Curious how the next generation will hold up.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 10-03-2013, 01:53 AM   #173
gtsvectra's Avatar
Hello All.
Now I'm after installation bi-xenon
I have a lot of pictures of the installation. If anyone needs.
regards m.
gtsvectra is offline   Reply With Quote
Old 10-03-2013, 07:55 AM   #174
BruceH's Avatar
Originally Posted by gtsvectra View Post
Hello All.
regards m.
That looks great! Nice job
DEPO Tail Lights
Old 10-27-2013, 03:15 AM   #175
Well its been a while, but I can provide some feedback on my black LED headlights supplied by Jeffrey at Xtreme.
Some may not know but I had some major dramas with the original model (One of the first to get the black coated model). Issues included:
- Cracked lens due probably caused by the heat of the halogen globe;
- Lens fogging;
- Fog light coating melted; and
- LED's orange indicator playing up.
I had to wait some seven months for the updated version and at this point thank Jeff for providing re-assurance that the lights would be replaced.
When the new one's came I'll be honest they looked the same although I understand the projector has been lowered slightly and 27w glove fitted to the fog lights.
I then waited another 6 weeks for some projector HID's, which managed to arrive in bits!
Anyway, finally found some time to install the HID's (see pics) and I can now confirm the lights are looking and working perfectly (except for some minor adjustment issues, which I'll sort out some dark night).
They get plenty of favourable comments and certainly update the whole look of the car.
Its almost a totally LED car now with rear lights, brake lights, interior lights etc all LED.
Oh - and HID's are a must for the Projectors.
Apologise for some of the pics as the sun was pretty bright
PCC010 is offline   Reply With Quote
Old 10-27-2013, 03:17 AM   #176
And one more pic
Old 02-21-2015, 02:35 PM   #177
Curious how these lights held up over the years? Are the 2nd Gen any better?
mack73 is offline   Reply With Quote
Old 02-23-2015, 10:43 AM   #178
That depends on what you mean by "better".
They seem to have addressed some of the issues with the lens melting and fogging, but that's about it.
If the price were ~$300, they might be worth it. Otherwise, purchase at your own risk
Old 02-23-2015, 07:43 PM   #179
Well that is a start I guess what are the issues that remain?
Old 02-24-2015, 10:04 AM   #180
Halogen bulbs, plastic projector (fire is hot), LEDs are low quality (burn out), they don't actually fit in/on the car, the alignment pegs break off due to low quality brittle plastic, foam rubber surround gasket holds water and rots sealant between outer lens and headlight body allowing water and dirt infiltration, "chrome" flakes off, paint flakes off, full of "cooling holes" which also let dust, dirt and water in.
