Old 01-03-2012, 06:37 PM   #1
WV Boxster
wvboxst3r's Avatar
help with radio removal
bought the tools- knives and put them into slots, they locked in but still no radio. Is there something else or what am i doing wrong.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 01-03-2012, 06:42 PM   #2
ddb
www.klisstle.com
ddb's Avatar
It take a good amount of force. If it becomes too tough on your fingers you can try placing screw drivers through the rings which creates handles instead of using your fingers.
Old 01-03-2012, 06:49 PM   #3
WV Boxster
wvboxst3r's Avatar
really that is it just force- lots of it
Old 01-03-2012, 06:55 PM   #4
ddb
www.klisstle.com
ddb's Avatar
Yep, that's my recollection. It has been years since removing my radio, but I remember it being tough to pull out and seeing pics in a thread of someone using screw drivers.
I'm sure someone will chime in if I'm missing something.
Old 01-03-2012, 07:02 PM   #5
WV Boxster
wvboxst3r's Avatar
ok, will do that in the AM. Not sure what I am going to do once it is out. I need serial # to get code. Dealer had work done before I picked up and did not reset. Once out I was thinking of replacing with aftermarket with some back speakers but like the factory look. Just priced a double din kenwood/ nav/ dvd installed and ac unit moved, new pocket all with parts and install for around $1200.
I just don't listen to radio much, on drive home 3 hours plus I enjoyed the car.
Old 01-03-2012, 07:10 PM   #6
ddb
www.klisstle.com
ddb's Avatar
Here's a thread where someone experienced a tough time getting the radio out.
http://986forum.com/forums/general-discussions/29832-no-sound-audio.html
I was just about to warn you about having the code before removing the radio.
If you haven't heard these radios, they don't sound all that great. I too like the look of the OE unit versus aftermarket single din units. I removed mine to add the rear speaker kit which helped. I do like the look of the double din units. There's a great kit you can buy to make the DD look like an OE installation.
Old 01-03-2012, 07:28 PM   #7
WV Boxster
wvboxst3r's Avatar
that price includes that kit. they tech just finished a 911 with the same install said it took a little over 3 hours and it looked nice.
Old 01-03-2012, 07:29 PM   #8
Registered Boxster abuser
healthservices's Avatar
I used a pair of pliers handles, I think I pulled outward as I pulled back. It took a couple times to get it completely out.
Radio won't go on after battery disconnect
Old 01-03-2012, 07:36 PM   #9
WV Boxster
wvboxst3r's Avatar
what did you put back in? with the crappy sound did you change out unit? I am looking for some samples of aftermarket systems.
Old 02-13-2012, 11:52 PM   #10
Just getting around to swapping out my cdr220. Going to install my Alpine CDA9857, PDX 4.100 amp and looking at B. Acoustics speakers all around. More than happy to share experience and pictures with everyone.
gtb02 is offline   Reply With Quote
