Old 10-06-2011, 05:52 AM   #1
Red face Tiptronic Transmission Filler Plug Question
I have a 2001 base model Boxster I need to drain, flush, and fill the transmission.
I know the drain plug is a 17mm hex bit, torqued to 59lbs
But what size is the hex bolt for the filler plug on the rear of the pan? Is it a M30?
thanks in advance for help
Teddy
TillTheEnd is offline   Reply With Quote
