Old 06-23-2011, 11:26 AM   #2
there is a tiny switch in the door handle. You can see it if you pull the handle open. Anyway, either the switch is fautly, or the connection is loose.
pull the panel and check.
part number 99661312500
2002 S
jhandy is offline   Reply With Quote
