					Originally Posted by ucsbjones
				 And the exhaust guy told me it was pebbles in between the shields and cat.  I got under there and watched him whack it with the rubber mallet and it seemed to make sense.  Am i nuts or is that possible? |
probably not pebbles, but whacking it seems to be what a lot of other people end up doing ( if it's the heat shield ) because that will deform it and make it stop vibrating...
if it does sound like pebbles ( or what most people say - rocks rolling around in a tin can ) then that's often how the IMS bearing failure is described...
