Old 06-19-2009, 11:29 AM   #1
Dension Gateway 500
I've read a ton of posts about how to hook up an iPod to a CDR-23. Most of them seem to conclude that the Dension Gateway 500 is the best answer, but I've never seen any info on the installation. I've been running a wired FM Modulator for about a year now, but I'm not happy with the sound quality. So, I ordered the Gateway 500 from bumperplugs.com. It just came in the mail, so I took a photo of everything that was in the box.
It includes (clockwise from bottom left):
RCA Cable
Power Cable
User Guide
USB Cable
Dension Unit
Install Guide
Fiber Optic Cables
iPod Cable
I'm gonna install it this weekend. I'll take some photos during the install and let you all know how it went.
lostdog is offline   Reply With Quote
Old 06-19-2009, 12:23 PM   #2
I scanned in some of the documents that came with it. On the source table I was most interested in mode 2, which should allow you to control everything via your iPod.
Old 06-19-2009, 12:43 PM   #3
Please let us know if it can display track name on unit itself.
Old 06-19-2009, 02:33 PM   #4
According to the manual, this depends on the capabilities of your head unit.
"We refer to the different type of car entertainment system as follows:
1. Browsing and playback: full music browsing capabilities and song information displayed onscreen.
2. Playback and text: name of the artist, album or track that is playing. The number of characters will be defined by your display type.
3. No text: only CD and track numbers displayed, for example, CD6-08."
I suspect the CDR-23 is a 3, but it might be a 2. Hopefully I'll find out tomorrow.
Old 06-19-2009, 04:28 PM   #5
Found these on the dension site:
Full Installation Guide (pdf)
Full User Guide (pdf)
Old 06-22-2009, 10:36 AM   #6
I installed the Gateway 500 on Saturday. It took longer than expected, but it's not complicated. The only tools needed were wire cutters / strippers, a very small flat head screwdriver, and the Porsche headunit removal tools.
Before you get started, you'll want to update the firmware if you can. There was a little red paper with a URL to get the update from, but the URL didn't work. I went to the Dension site and found the firmware in their downloads section. Looking at the sticker on my unit showed that I have the 2.16 firmware. The one I downloaded was 2.18. However, it requires a USB flash drive to install. I didn't have one, so I couldn't update it.
The first thing I did was layout the fiber lines on my table. They aren't super fragile, but you don't want to bend them at sharp angles as this will break the fiber.
Next I pulled apart the console, pulled the headunit, and removed my old FM modulator. I didn't want to disconnect power from the head unit because then I would have to enter the unlock code. So, I just wrapped it in a towel to keep it from scratching up my center console.
Then I cut the power cable down to about a foot and stripped the ends. It was really long, and the connection is right there. I just plugged the end of the lines into the phone power (I think that's what that plug was intended for). The brown is ground, and the green/red is power.
Now I started messing with the fiber. There is a line from the car that plugs into the back of the headunit. I disconnected one of the lines from this plug so I could hook everything up as shown in the install diagram, but the end of the stock fiber line was different from the provided fiber. Then meant it wouldn't plug into the provided connectors. So, I put the fiber back in the stock connector and reconfigured the fiber as shown below. There were extra fiber lines and connectors for setting it up with a cd changer. Since I don't have a cd changer, I just used those extra bits.
Be very careful to route the fiber so that the light goes in a continuous loop. The lines themselves aren't directional, but you need to watch which side of the connector you plug them into. Each connector has arrows on it indicating which side the light goes in and out of.
Now comes the tricky part; plugging it all together. At the very front of the center console there is a nice empty space to put the dension unit. This is below the head unit. Put the fiber triangle in from above and route the dension plug down there. You can use a spare piece of wire to help pull it down if needed. Just be care not to bend / snap the fiber.
Now just snap everything together. Plug the car side and head unit fiber plugs in. Put the head unit part way in, but don't snap it all the way in until you've tested it. Now just plug everything into the Gateway 500. You'll need the power, fiber, and iPod cables. I left out the USB and RCA outs since I don't plan on using them, and don't want any more cables hanging out.
So, with everything connected, turn on the car and check that you get sound through the stereo. It was at this point that I tried to switch to the cd changer input by pressing the cd button and discovered that I need to have that enabled by the dealer. Damn! Oh well, I was getting sound from the radio which shows that the fiber is routed correctly.
I'm gonna call my local shop this morning and see if they can enable the cd changer for me. I'll post again once I have it working.
Old 04-09-2014, 01:56 AM   #7
Boxster S '53'
Attempting to revive an old post with some people who have the know how.
I have a Bosxter S late 2003 with the cdr 23, Bose & attached cd changer. Im looking to connect my phone 5s (& future iPhones) to the system to play music. Have read countless posts on this already but have some more questions / issues.
Firstly there are issues with my cdr23 - it makes a clicky noise when the car is un locked & then again when the car is turned off. Also it sometimes doesn't know there s a cd in it - won't eject & the cd button does nothing. I have to turn the car off to resolve it.
Also it doesn't seam to recognise the factory cd changer in the frunk, Cd changer ejects & allowes me to ad cd's but no matter how may times I press the cd button to cycle from the cds to the cdc it doesn't do anything.
So thats the issues... now the plan. Will the cdc issue mean that the denison unit wouldn't be recognised?
Say i get everything working will both the denison unit & cdc both work or does the denison replace the cdc?
What is the sound quality like with the denison?
Has anyone installed the Bluetooth denison?
Being a rookie Porsche owner I have lots to discover, I'm sure a lot of self discovery but hopefully a little help from you guys. Much appreciated.
Blankman is offline   Reply With Quote
Old 04-09-2014, 11:00 AM   #8
Before I give you an answer to each individual question I will generically state you will be much better off and happier by just pulling out existing garbage Porsche put in as a sound system. Particularly so since you are experiencing problems w/ the system.
It most likely will be an issue as the CDR23 recognizes the Dension unit as a CDC
Desnion replaces the CDC BUT there is an override switch w/ the Dension to allow it to act as a passthru. Would you really still use CDs if you had ipod hook-up?
basically same as any other MP3/ipod hook up device. Not spectacular but acceptable.
Seems fruitless in a convertible but it has been done.
Again, you're better off just going after-market w/ a system that includes iPod/Phone integration, Nav, Bluetooth, etc.
Good luck!
"Cool Prius!"
- Nobody
Old 04-09-2014, 02:49 PM   #9
Boxster S '53'
I was afraid of that being the answer! Its a bit annoying as I held out on buying a few cars as they did not have the bose system.
Can any of the system be utilised i.e change just the head unit / just the head unit & amp? Is there some sort of fibre to standard converter? are the speakers connected by fibre or standard copper wiring?
Im quite happy with the way it all sounds now just want 100% working & iPhone connection & thats iPhone for music & to charge it, not bothered about calls.
Ive changed many a head unit, speakers over the years in various cars but never a fibre system. & I also built a custom set up for iPhone 5s for my work van to hold, charge & play music through rca aux in to a standard aftermarket head unit. The sound quality there is perfect. I just slot it in to the lightening connector dock, no fiddling around with a 3.5mm jack & it all works seamlessly.
was very much hoping I could just make another for the Porsche.
Your right I don't care if the cdc or cds for that matter work once I've set up the iPhone connection - never used the cd slot or radio for that matter in my van!
Old 04-09-2014, 03:45 PM   #10
If you change h/u you either need to:
- find a fiber optic h/u (there are a few as I recall)
or
- also replace amp
Set up (aside from fiber optic loop b/w CDC, H/U and amp) is same as any other audio system... copper wire from amp to drivers. That said, BOSE is sometimes known to do wacko things w/ speaker impedance so check the drivers first for compatibility w/ aftermarket amps. Even then, I'd consider replacing most of the drivers too.
BOSE = Great marketers of just ok sounding stuff (if you like it really 'boomy')
Good luck
"Cool Prius!"
- Nobody
Old 04-09-2014, 07:28 PM   #11
I have a CDR-23 in excellent shape just sitting in the garage right now if you are interested in swapping out your head unit. PM me and we can work something out.
Old 04-10-2014, 01:13 AM   #12
Boxster S '53'
Thanks for the info, I can see things much clearer now!
I have noticed the clarity of the system isn't anything amazing, though I do have a airplay bose speaker in my home which has amazing clarity, but yes bose are know for there general love of bass! but I'm fine with it driver wise.
Ive had a look for fiber optic h/u but as yet not found any... Not asking you to search for me but do you recall any brands / models?
Looking for as little work as poss as I finally thought buy a nice car & I wouldn't have to mess around with the stereo etc but looks like the dream of that is slowly....make that fast slipping away!
dghii- Thanks for the offer & ill keep it in mind if I decided not to bother with iPod connection. guessing it is fully working & your have the radio code?
Old 04-10-2014, 12:53 PM   #13
No problem. I actually have two of these units one is working fine in the car and another from a member who replaced his system. I got a good price (for a backup) and am willing to pass it along.
There is no radio code for these units. The radio is enabled by the dealer once you install it.
Old 04-10-2014, 07:02 AM   #14
Blankman I'd pass on replacing what you already have w/ another of same. Why? B/c you'll again face the same issues sooner rather than later. Furthermore, someone didn't remove theirs b/c they loved it so much and wanted to save it for posterity - LOL.
Of hand I do not recall specifically who makes an optic compatible unit but check the regular suspects lik Pioneer, JVC and Apline. That said, depening on the unit itself, you may be able to bypass the existing amp all together and wire the drivers directly to the h/u.
I suspect if you truly look at all the overpriced add on options you would like to have (Dension, Bluetooth, Nav), you'll quickly see how much better a decision it is to just scrap the exiting and go aftermarket. It's a tough pill to swallow up front but in the end it makes more sense.
Good luck and search here and on 6SpeedOnline for more info as many others have preceded you on this journey.
"Cool Prius!"
- Nobody
Old 04-12-2014, 02:49 PM   #15
inveniam viam aut faciam
It is funny that this thread just popped up again. I was given one of the Dension Gateway 500s earlier this week from a used car dealer friend who removed it from a car they were troubleshooting. I removed my CD changer and plug it in there in my '03 S and it seems to work just fine. I would like to leave the unit in the front storage area in place of the CD changer and run in the iPod cable.
Have most people installed these in the center console under the radio?
Qmulus is offline   Reply With Quote
