Old 09-20-2019, 08:43 AM   #341
On an upward angle and a sharp punch works better than a drill.
Old 09-20-2019, 08:45 AM   #342
M9G
2002 2.7 Boxster in green
M9G's Avatar
All done and de-snorkeled :-)
Mine are more to the side but I assume its all going into the same chamber
Cheers :-)
M9G is offline   Reply With Quote
Old 09-20-2019, 09:42 AM   #343
Yep
Old 09-20-2019, 12:58 PM   #344
M9G
M9G's Avatar
Yep
sweeeeeet :-) thanks for your help, much appreciated
Old 12-13-2019, 03:43 PM   #345
+1 satisfied DIYer. Did this on my 03 base and it sounds a little louder than stock! Drilled 3/8th size holes. I'll go larger if I want more sound later on.
bigfy39 is offline   Reply With Quote
Old 08-29-2020, 09:29 PM   #346
After reading many of the posts I used a few tips from several people and did my mod in probably 5 mins. I have a a 2000S with welded tips and was having problems getting the right angle and getting the drill bit to bite. I used a long screwdriver and used it as a punch and made an X shape and then I had a large lag bolt I ground down on my grinder ( didnt have a long 1/2 bit handy) and then used it to finish the holes.
Spent more time reading through all the posts than it took me to do it. If you are handy and have welded tips then there are several ways to make this work. This was what I used to knock it out tonight.
DPhantom679 is offline   Reply With Quote
Old 01-07-2021, 08:19 AM   #347
Veteran & Boxster Padawan
Farmlifer's Avatar
So does anyone has a recommended 1/2 or 3/8 drill bit that won’t break?
My 2001S has welded tips and I don’t have a grinder to fabricate a punch. Want to do this modification but hear of broken bits and frustration for some...
Farmlifer is offline   Reply With Quote
Old 01-07-2021, 11:33 AM   #348
See DPhantom's post just above yours. A long flathead screwdriver serves as a good punch to locate the bit.
98 Arena Red 986
Old 01-07-2021, 03:50 PM   #349
98 Arctic silver 986
tommy583's Avatar
Old 01-08-2021, 07:05 AM   #350
Farmlifer's Avatar
Thank you much, have the drill bit now from HDepot will give the screwdriver a try this weekend and get some noise? Drill bit was just sliding all over when I tried yesterday without...
