Old 07-26-2008, 07:27 AM   #1
Replacing 99 Tiptronic front pump half
Can anyone tell me where to find information on how to replace the front pump half in a 5hp19 Boxster Tip? I ordered the pump through a ZF distributor. I need torque specs and preferably a procedure.
bbced is offline   Reply With Quote
Old 07-26-2008, 08:00 AM   #2
A rather involved task for a DIY. How did you determine the pump is the problem?
wvicary is offline   Reply With Quote
Old 07-28-2008, 10:40 AM   #3
99 Tiptronic Front Pump Half
The bushing in the front pump half spun. Trans worked perfectly other than leaking and was driven in the shop. This happened after a rear main seal was replaced. Don't need assistance on the diagnosis. Just torque specs and anything complicated that might come up as Porsche does not supply any service information on the tip.
Old 07-28-2008, 11:01 AM   #4
Might find Group-3 Automatic useful
http://www.cannell.co.uk/Manuals.htm
