Old 08-17-2012, 01:08 AM   #9
Andrew McD's Avatar
Bryan, the one listed in the instructions is the correct one. I did not check what i'd been sent, not thinking there would be two. It's incorrect part number is; 996 613 127 00. If you, as I was, are buying the parts used, you should be able to ask for the plug connector too, as that makes things a bit easier.
Twitter if anyone is interested... @JAZ5788_Boxster
Boxster 2.7 with a few mods: RSS Under drive pulley, Dansk OEM look polished stainless steel sports silencer, K&N air filter, Full new M030 Sports Suspension, 997 Gear selector, and a load of other OEM styling upgrades.
Andrew McD is offline   Reply With Quote
