Old 03-07-2008, 09:18 AM   #1
Replacing rear radio fuse
Whats the best way to access the fuse located at the rear of the radio (CDR220)?
gbox is offline   Reply With Quote
Old 03-07-2008, 11:54 AM   #2
pull the radio using a set of keys that look like these....
if you don't have a set, stop by a local radio installer and borrow theirs for a minute. Once you get the radio out, push the blue clips in on the side to release the keys.
Also, to prevent slicing off your fingers, drop screwdrivers into the holes in the keys and pull on the screwdrivers. Pull hard BTW
Old 03-08-2008, 09:16 AM   #3
Thanks - I'll give that a try.
