Old 08-01-2007, 10:15 PM   #1
DIY Seat Belt Replacement
Since no one was able to supply me with a DIY guide to install my red seat belts, I decided to make my own. I did some reading on rennlist about 996's and 987's seatbelt replacement and I then tackled the job. Here is my overly detailed DIY Guide to Seat Belt Replacement
I have only supplied the photographed dissembling of the OEM seat belts, just reverse the photo process and that will complete the project.
Time Required:
30 MIN for two belts
Tools Needed:
Torque Wrench, to replace the bolts at 36lbs
Metric Wrench Set : 8mm, 17mm
Flathead and Phillips Screwdriver
BEFORE STARTING DISCONNECT THE BATTERY!
FAILURE TO DO SO WILL RESULT IN FAULT CODES AND FAILURE LIGHTS UPON DISCONNECTING WIRES
>Step One: Remove the Cover
Remove the screw holding on the lower part of the cover
Next, Loosen the small bolt holding on the upper part of the cover
Pull the Cover Strait up to expose the Seatbelt Mechanism
**The Order Does Not matter, but I removed the Mechanism Last and I am going to reflect that here.
>Step Two: Unbolt Upper and Lower Harness Mounts
Pop open the cover and unbolt the top section of the harness.
Next, Pop off the cover and unbolt the lower section of the harness.
***CONTINUED***
http://img412.imageshack.us/img412/9591/65zxg8pcz4.jpg
2002 Boxster S
Guards Red/Black
Hacks: De-Snorkeled, Clutch Swich, Debadged, Red Seatbelts, Painted Bumperettes,
986S Badge, EVO Intake, SuperSprint Exhaust, Fabspeed Cat Bypass
My Car: http://s220.photobucket.com/albums/dd74/zackwatt/
zackwatt is offline   Reply With Quote
