Old 05-23-2007, 06:23 PM   #1
Replacing External Mirror Glass
Hi Guys,
Can abyone help me on how to remove the mirror glass from the external rear view mirrors. I have smashed one & need to replace it.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 05-24-2007, 11:01 AM   #2
Perfectlap's Avatar
very simple, I just replaced my driver's side(left here in US) mirror with an atmospheric one that has a blind spot eliminator.
I simply turned off the car gently wedged my fingers between the glass and the housing and gave it a yank. Don't pull too hard because there are two wires that connect to the back of mirror. The mirror will seperate and then unlug the wires.
I unplugged one wire and plugged it into the new mirror and then did the second wire so I wouldn't get them backwards. Once both are plugged in just push the new mirror into place. No tools required.
I might wear gloves if there is broken glass.
http://e-partssales.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=99673103502and99673103602
BORN: March 2000 - FINLAND
Old 05-24-2007, 01:20 PM   #3
Send a message via AIM to djomlas
so what does the back of the mirror look like?
its not flat i assume..
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 05-24-2007, 02:22 PM   #4
actually, they are flat.
the "Aspheric" part comes from the part of the glass that has a different aspect ratio on it.
look at this page.
Asperic Mirrors
Clem-Clone is offline   Reply With Quote
Old 05-24-2007, 02:39 PM   #5
i knew that, but just wasnt sure how the actual glass connects inside the mirror housing.
but looking at that sire its obvious now.
Old 06-11-2007, 05:28 PM   #6
The mirror housing itself is connected using three screws (one of which is hidden pretty well). The mirror itself is connected by two wires (which I believe are for grounding) and a clip on the far side of the housing relative to the car. To remove the mirror you just simply pull it out by pulling the side furthest from the car's A-pillar. The mirror's backing has a circular like clip pattern that goes around the mirrors circular platform to move it.
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
