Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 05-16-2021, 04:31 AM   #1
Bilstein B16 PSS 9 valving with Swift springs
Update:
I'm reviving this post as I've been unable to find answers. Perhaps this is part of the secret sauce people use in their setups? Has anyone had their shocks re-valved for the stiffer rates of the Swift springs. I would expect good gains as the shock must be working very hard to control the heavier springs. Or is there enough adjustment to increase rebound dampening sufficiently? My track time is extremely limited, so I would like to show up with the setup as close as I can get.
Older post from 2021:
I have this suspension on my car, but I'm not able to get the papers needed to get them street-legal ( I live in Europe) because the Swift springs are not TÜF approved. Bilstein recommends reverting to the original springs which will make the kit street legal.
Does anyone know if the shocks are re-valved for the heavier Swift springs?
Here are the part numbers in case it helps.
Part number of the front shocks: VM35252
Part number of the rear shocks: VM35253
1990 944 Turbo
2007 Renault Clio RS 197 (Sold)
1998 Boxster 2.5L Track Day/ Race Car
2011 Mistubishi i-MiEV
Norway
Bebbetufs is offline   Reply With Quote
Old 05-21-2021, 11:59 AM   #2
Unless someone sent them off for revalving they are most likely stock. Bilstein has such bad customer service in the US for service and rebuilds, I know of no one that has done this.
The Swift spec Boxster springs (I'm making an assumption that is what you have) are race parts and will probably never be TUV/TUF approved.
I don't know what level of scrutiny your inspectors strive for, but do you think they really know the difference between a blue or green main spring?
PCA Intermountain Region Track Chair
SPB #50
MaxD is offline   Reply With Quote
Old 05-21-2021, 12:51 PM   #3
For aftermarket suspension they check the serial number of the springs and shocks and the numbers from the TUF approval must be entered into the vehicle registration card.
I'm surprised the shocks are stock. There must be a lot of tuning potential there if they are valved for softer springs. Is it common for 986 racers to tune their shock absorbers?
1990 944 Turbo
Norway
Old 05-21-2023, 12:22 PM   #4
Updated first post to see if anyone has more info to share now.
1990 944 Turbo
Norway
