Old 07-20-2019, 06:33 AM   #1
Top down
Send a message via Skype™ to Pastor T
Best performance mods
What are the best performance mods to add to a 2000 2.7.
Pastor T is offline   Reply With Quote
Old 07-20-2019, 07:39 AM   #2
"50 Years of 550 Spyder"
10/10ths's Avatar
Simple.....
.....Diet and exercise and a good driving school.
Old 07-20-2019, 08:00 AM   #3
Who's askin'?
maytag's Avatar
True that!
Old 07-20-2019, 08:21 AM   #4
Topless's Avatar
... And good tires
Old 07-20-2019, 11:52 AM   #5
Shapeshifting Lizard-Man
WizardSmokey's Avatar
good tires, good fuel, and seat time.
But since that's the most generic answer ever, I'll also throw in:
1) Weight savings. The 986 is surprisingly heavy given it's size. (~2900 lbs stock)
2) Camber. The rear factory limit is about 2.5-2.7 degrees, which isn't bad, but the front is less than 1 degree.
3) Short shifter. This one, specifically: https://uniwerksdesign.com/product/bens-porsche-996-986-short-shifter/ Amazing quality, and lower price than most others.
4) Thermostat. After a couple of hard laps, we noticed the temperature creeping up. The car never overheated, but we figured if we can keep it down, we could. You can get a 160 degree thermostat, vs the 180 degree stock.
5 A full exhaust, if only to let the M96 sing her song.
WizardSmokey is offline   Reply With Quote
Old 07-25-2019, 02:52 PM   #6
Cunningr's Avatar
Plenum and 74mm throttle body, several ways to accomplish and I will not open the debate between them. FVD Exhaust, chip tune.
Old 07-25-2019, 02:56 PM   #7
Ciao's Avatar
Agee; these are also great for a 3.2 "S"
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 07-25-2019, 07:35 PM   #8
Qingdao's Avatar
N20....
I'll leave this here.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
Old 08-25-2019, 09:54 AM   #9
Depends on what your purpose/goal is.
AutoX & track = Front GT3 control arms, tires, & alignment.
Going fast on highways - plenum, header, & exhaust.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 09-04-2019, 08:33 AM   #10
Besides good driving instruction and fitness, I would start with the low hanging fruit first.
A deeper sump to add some engine protection.
An under drive pulley is the cheapest 5 HP you can buy and will also protect your power steering pump on the track.
DOT 4 brake fluid for a higher boiling point and stainless steel braided flexible brake lines to replace the 19 year old rubber ones on your car.
A CG-Lock to keep the lap portion of your seat belt snug if you are running stock seats so you can concentrate on driving instead of bracing yourself.
Old 09-04-2019, 10:24 AM   #11
Who's askin'?
maytag's Avatar
What type of performance are you looking for? Straight-line top-end? Stop-light drags? Or real performance at a road-course racetrack?
Or are you (like me) simply addicted to modifying and think of performance gains in the process?
