Old 09-04-2019, 08:33 AM   #10
PaulE
Besides good driving instruction and fitness, I would start with the low hanging fruit first.
A deeper sump to add some engine protection.
An under drive pulley is the cheapest 5 HP you can buy and will also protect your power steering pump on the track.
DOT 4 brake fluid for a higher boiling point and stainless steel braided flexible brake lines to replace the 19 year old rubber ones on your car.
A CG-Lock to keep the lap portion of your seat belt snug if you are running stock seats so you can concentrate on driving instead of bracing yourself.
